need urgenty help.
Re: need urgenty help.
Postby ake » Sun Jan 03, 2010 8:21 pm
Locost have you checked and cleaned all the starter cable connections, including the earths :?:
Postby locost1 » Sun Jan 03, 2010 8:28 pm
no. now having trouble understanding all this.
to clarify i need to..
.. check cables and connections to starter and battery,
..change battery
..check the teeth on the starter?
I think iam going to change battery,
the starter is of a 1999 transit, would this be ok or shell i take it back off and count the teeth? :?
http://www.tjtransport.co.uk
1989 Mk3 luton 2.5. now it runs!!
locost1
Postby ake » Sun Jan 03, 2010 8:32 pm
locost1 wrote:no. now having trouble understanding all this.
.. check cables and connections to starter and battery, YES
..change battery Charge First
..check the teeth on the starter? Yes
If both vans are diesel then the starters should be compatible but no harm in checking
Postby KH_Towbars » Sun Jan 03, 2010 8:37 pm
yes give battery a decent charge overnight at least 12 hours
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Postby locost1 » Sun Jan 03, 2010 8:57 pm
ok i will try and put it on charge tonight. Its a halfords 4 year warrenty so will try and exchange it but i have no proof of purchase!
thanks everyone.
locost1
Postby locost1 » Mon Jan 04, 2010 9:33 pm
hi.i got another battery on charge so will try that.
The starter motor on it is from a Vreg transit. Same teeth as the one i pulled off(13). Would this be ok??
locost1
Postby ake » Mon Jan 04, 2010 9:39 pm
locost1 wrote:hi.i got another battery on charge so will try that.
Yes
Re: need urgent help.
Postby locost1 » Mon Jan 04, 2010 9:41 pm
thankyou.
locost1
Postby locost1 » Mon Jan 04, 2010 11:19 pm
my battery is charging now. My volt meter says 13.1volts when i take of the charger its saying 12.7
Are these good rates?
locost1
Postby locost1 » Mon Jan 04, 2010 11:34 pm
just been reading other posts.
There are 2 earth wires on mine. main one goes to a terminal on the starter and the other smaller on goes into the harness.
Should the main neg battery strap go to the starter? Not the mounting bolts but the terminal on the starter!!
Should there be one that connects to engine somewhere??
Anyone live near Warwick, Warwickshire. Midlands!!!!
locost1
Postby KH_Towbars » Mon Jan 04, 2010 11:37 pm
yes 12.7 is just enought to start engine but how long has it been on charge? it does need a decent charge like i said at least 12 hours. I bought a battery today as mine failed 10 mins before I had to collect my daughter from school - not good, i was 25 mins late by the time i got someone to pick me up! also leave the battery al least 10 mins before you get a reading as the voltage does tend to drop when you first take it off charge then it will settle at its true voltage :D
SOLD VW T5 102 SWB
KH_Towbars
Postby locost1 » Mon Jan 04, 2010 11:40 pm
its been on charge now for about 5 hours.
Also there is only one main neg battery lead is this right
locost1
Postby KH_Towbars » Mon Jan 04, 2010 11:41 pm
locost1 wrote:just been reading other posts.
I would be tempted to put an extra earth cable to the body or chassis from battery but the problem in hand is on starting and there is no better than battery to started as long as the connections are clead (free from rust)
SOLD VW T5 102 SWB
KH_Towbars
Postby KH_Towbars » Mon Jan 04, 2010 11:45 pm
locost1 wrote:its been on charge now for about 5 hours.
on the newer vehicles the battery is normally just earthed to the chassis
SOLD VW T5 102 SWB
KH_Towbars
Postby locost1 » Mon Jan 04, 2010 11:46 pm
just to be on the safe side i brought 2 new leads from halfords.
Thats when i noticed that the earth went straight to the terminal on the starter. shell i keep the battery on charge over night?
I removed the bung screws things from the top of the battery. will this be all safe?
locost1
