D.I.Y Sandblasting
Re: D.I.Y Sandblasting
Postby bazw » Thu Jan 28, 2010 12:03 am
darkbluevanman wrote:
bazw wrote:baking soda works well on tin but wash well and dry very well afterwards
I wouldn't let a bead of sweat near bare metal... even with drying!
true and i must start reading what i type and then post lol
i meant to say
"blow off well with air and wash down well with thinners then dry well afterwards "
must of been having an old people moment :?
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby jud » Thu Jan 28, 2010 10:14 pm
I might be wrong, but it looks like 14-15 cfm's all i'm gonna get on single phase 240v?.
jud
Postby bazw » Fri Jan 29, 2010 10:42 am
have seen 18 cfm on 240v from machine mart ,
if 14-5 is all you can get try and get one with a big tank so it has a chance of working for a bit before you need to let it fill up and try to run the output pressure as low as you can and still take stuff off , they are designed to work at 90 psi for blasting but if you can take the slower removal at say 60 it gives the pump more of a chance to keep up
also the lower pressure is less likely to warp tin sheet with heat :wink:
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby snap-on » Fri Jan 29, 2010 11:14 am
jud wrote:thanks for that snapon!. what set up have you got (if you don't mind me being nosy?). I don't know much about compressors and pnuematics but I know a bit about sand!, I reckon that would be silver sand ( its the finest building sand and about £60 a ton) and it nearly flows like water when its really dry. If that sands ok then sandblasting ain't gonna be a dear passtime (is it??). 14 cfm SIP compressor coming up for sale. Do you reckon it could cope at a push? . i know you advise 15cfm minimum bazw but there ain't one about in my price range just now and I'm wanting to get on. I ought to learn patience 'eh.
Sorry for the delay in answering mate I have a 3hp V twin 50ltr 14 cfm single phase and a 2hp 50ltr single phase both running :shock: but it works :wink:
Bit of advice dont get one of these they are C#@p
Dave
snap-on
Postby jud » Fri Jan 29, 2010 8:45 pm
thanks lads!. gonna look into the 18cfm machine mart machine 'cause i would like to be yon' side 0f 15 cfm ( no point asking advice and not followin it 'eh?) I'm rarin to go here!.
jud
