should but you got keep in mind how much you use it nothing worse then gagging for a brew an both batteries low on power so you start engine an it charges van bat not leisure
try an get a 200ah if you can
mrT wrote::arrow:Gas bottle and stove for the tea . .
dirtydog wrote:Just ressurecting my ols thread.
Excuse the silly questions I've had the relay for a while now but the instructions have gone missing!
Finally getting around to sorting this out, I've got a brocot smart relay and just need to know if it's best to run the - neg and + pos inputs from the battery or just the + pos and then earth it to the van?
Where do I need to put 2 fuses in, one at the battery but where does the other go?
And do I earth the leisure battery to chassis?
Or if it's easier anyone got some instructions they can scan and send me?
Thanks Adam
robbie.cee wrote:surely 100 amp cable to join batteries? and 120 amp fusible link at second battery, 100 amp fusible link at main battery
MrMPuk wrote:robbie.cee wrote:surely 100 amp cable to join batteries? and 120 amp fusible link at second battery, 100 amp fusible link at main battery
The fuse ALWAYS needs to have a lower rating than the cable, you want that to fail before the cable.
