Mk3 Transit SVO Codes (special vehicle order) Help.
Re: Mk3 Transit SVO Codes (special vehicle order) Help.
Postby AlanN » Tue Dec 14, 2010 1:49 am
Are the MK3's covered on the etis disc?
Postby AndyG » Tue Dec 14, 2010 1:52 am
Will check, but isn't very friendly :|
Postby AlanN » Fri Dec 17, 2010 3:55 pm
Just a few images of SVO for MK3 and MK4. Not sure what was carried over to the MK5
Under bumper fog kit
Towing Leveling kit?
Dash top pod
Postby AlanN » Fri Dec 17, 2010 3:57 pm
Heres a good one! Looks like some sort of heater under the door step
Postby Luke » Fri Dec 17, 2010 4:01 pm
nice 8) where did you get this from Al :?:
Postby AlanN » Fri Dec 17, 2010 4:48 pm
Ive just sold all my parts list for MK2 Cortina's and decided to look for a MK3 transit one, but I could only find MK3 on microfiche, I stumbled on a small parts book for the mk3/4 book on ebay
Postby AndyG » Mon Dec 20, 2010 2:37 pm
There's loads of nonsense on the cat..............
You might find this bolt on bumper cover interesting...............
Postby AlanN » Mon Dec 20, 2010 3:06 pm
Wow! that would have made life a lot easier 8)
Postby rover » Mon Dec 20, 2010 5:04 pm
AlanN wrote:Wow! that would have made life a lot easier 8)
Ahh who needs an easy life? :lol:
All this talk of SVO's maketh me jealous :(
I even had to change my wiring loom just to fit the autobox :roll:
rover
Postby AlanN » Mon Dec 20, 2010 5:25 pm
Wish more of this stuff was off the shelf :lol:
Postby webbysdad » Sat Oct 22, 2011 12:29 pm
My lad has got an ex-ambulance and obviously a lot of SVO options. The list is as follows:-
Option Selection Meaning?
7502 272 Aux switch panel and various switches and instruments?
7514 1 Rear anti-roll bar fitted
7515 1 Poss front anti-roll bar. (one is fitted)
7520 3 Front fog lights are fitted.
7526 11 Additional fuse/breaker box fitted in glove box.
7549 2 Filler neck guard fitted.
7551 1 ?
7558 8 ?
7559 6/A ?
7560 1 ?
7586 1 ?
7589 4/A ?
7631 3 ?
7639 31 ?
Also perhaps someone can check the info on the type plate please.
ENG B4T Assume this is 2.9i V6 as that is what is fitted.
Rear axle type M
Ratio G What ratio is this? Any ideas?
Hope someone can shed a bit of light, cheers.
webbysdad
Postby IRMA999 » Sat Oct 22, 2011 12:57 pm
:shock: Had to do a double there,i used have an SVO TRANSIT D reg and it too was black.Mine was a LWB twin wheel job at the back,with a petrol essex V6 8) and a 4 SPEED overdrive box.I do miss it so fast and soooooooo quiet :lol:
Mmmmmmmm 140 GLX with the toys.....
IRMA999
Postby AlanN » Sat Oct 22, 2011 4:46 pm
webbysdad wrote:My lad has got an ex-ambulance and obviously a lot of SVO options. The list is as follows:-
7551 1 ?
7558 8 ?
7559 6/A ?
7560 1 ?
7586 1 ?
7589 4/A ?
7631 3 ?
7639 31 ?
Rear axle type M
7502 272 dash pod - Aux switch panel and various switches and instruments?
7551 1 not listed in my book
7558 8 uprated spring and shock
7559 6/A something to do with twin batteries!
7560 1 volt meter
7586 1 not listed in my book
7589 4/A not listed in my book
7631 3 tilting seat base
7639 31 not listed in my book
M - 53 Heavy Sailsbury (less LSD)
G = 4.36:1 ratio
2.9 efi was fitted to the later one Essex to the earlier ones
I havent got the microcat anymore, computer failure, so I cant cross reference them, maybe AndyG can
Postby webbysdad » Sat Oct 22, 2011 10:12 pm
Thanks for that Alan. The ambulance has twin batteries with a big red breaker in the engine bay which can be operated from a dash push button and has a volt meter in the aux pod. I guess the fig 272 for 7502 means the selection of switches in the pod.
I can understand the uprated springs and shocks as it is fitted with front and rear anti-roll bars and corners flat, even though it is a high top! Not sure about the tilting seat base though. Any idea which seat it refers to?
Look forward to hearing if anyone else has any info. Cheers.
webbysdad
Postby AlanN » Sat Oct 22, 2011 10:32 pm
webbysdad wrote: I guess the fig 272 for 7502 means the selection of switches in the pod
Yes, I think so, as some of them have extra numbers with each button or loom or lamp etc. I'd like to find a full list, I'll have to try and get another microcat
