12volt problem
Re: 12volt problem
Postby CraigMac » Sat Jul 31, 2010 6:04 pm
The solar panels that your talking about do have a tendency to discharge the battery...... Get your leisure battery hooked up to the alternator via a split charge relay....this will solve your problems guaranteed :D :D :D
Regards Craig
CraigMac
Re: 12volt problem
Postby Scooby999 » Sat Jul 31, 2010 7:28 pm
CraigMac wrote:The solar panels that your talking about do have a tendency to discharge the battery...... Get your leisure battery hooked up to the alternator via a split charge relay....this will solve your problems guaranteed :D :D :D
i think this is the way to go but for the time being i just got a briefcase solar panel 4w with built in diodes so it cant discharge the battery(was £30 now£15 at maplins) the other 1 was only 1.5v with no protection
also have charged battery (12.80v) but still losing power so going to replace the 12v socket and the wiring and start again :( :(
Scooby999
Re: 12volt problem
Postby MrMPuk » Sat Jul 31, 2010 7:30 pm
Scooby999 wrote:also have charged battery (12.80v) but still losing power so going to replace the 12v socket and the wiring and start again :( :(
How do you mean losing power? Don't think replacing the wiring is the answer!
Re: 12volt problem
Postby APH » Sat Jul 31, 2010 8:28 pm
Sound's more like dud battery, or cell. connect meter to battery terminals, then plug something in and see if the battery voltage still dissapears, if so, your battery is f@##ed :(
(\__/)
(")_(")
this is bunny
APH
Re: 12volt problem
Postby Scooby999 » Sat Jul 31, 2010 8:50 pm
ok will try tomoz
:shock:
Scooby999
Re: 12volt problem
Postby Scooby999 » Sun Aug 01, 2010 6:40 pm
al sorted now ,the battery needed charging and topping up with fluid, i also ran a new earth to the battery and then to the body(dont know if i needed to have an earth to the body but cant hurt),and soldered all the connections.
Thanks for the help on this .I think i will have to get a new battery at some point and get it all wired through the alternator
Scooby999
