Oil problem after changed filter and oil...
Re: Oil problem after changed filter and oil...
Postby winterheating » Tue Jan 25, 2011 1:13 am
because its been overtightened when it was put on.
the allen key is just a drain, they used to put on the early ones.
Make sure youve got the oring on right aswell.
winterheating
Postby hegg715 » Tue Jan 25, 2011 1:19 am
winterheating wrote:because its been overtightened when it was put on.
i see so most likely be the housing? will check all of above thanks
will she be ok?:( lol
hegg715
Postby winterheating » Tue Jan 25, 2011 1:21 am
youve allready checked the aluminium housing havnt you?
more likely to be the plastic filter bowl, as the nut has had to much force on it and cracked somewhere round it....
but as said could also be the aluminium housing if youve missed the crack.
winterheating
Postby hegg715 » Tue Jan 25, 2011 1:25 am
winterheating wrote:youve allready checked the aluminium housing havnt you?
na was told about it tonight and told to come on here and see if its a common thing, quite glad i have joined...sounds like a gd bunch!
hegg715
Postby winterheating » Tue Jan 25, 2011 1:29 am
Got there in the end lads :wink:
winterheating
Postby Altransit » Tue Jan 25, 2011 1:30 am
winterheating wrote:Got there in the end lads :wink:
:D :wink:
Postby hegg715 » Tue Jan 25, 2011 1:34 am
hopefully get van back to full potential tomorrow, maybe even use some tips on here to make van better also, its quite a big deal as i race 2ltr national saloon stockcars and she gets me up and down the country!
hegg715
Postby winterheating » Tue Jan 25, 2011 1:40 am
whats your reg and we can check what diff you have for starters.
i take when you say better you mean faster :?: :lol:
winterheating
Postby hegg715 » Tue Jan 25, 2011 1:48 am
erm aye n a tad quieter the fan belt makes some screech lol
Y793 VOF any sites that will tell me full details of it?
hegg715
Postby TIMO » Tue Jan 25, 2011 1:49 am
hegg715 wrote:erm aye n a tad quieter the fan belt makes some screech lol
Transit 2000, 2.4L Duratorq DI (90PS), Diamond White 73
VIN Number: WF0LXXGBFLYD10900
Registration Number: Y793VOF
Registration Date: 31.05.2001
Registration Country: GB
Primary Features
Build Date: 26.07.2000
Vehicle Line: Transit 2000
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: 2.4L Duratorq DI (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.63
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Stylize (-G-C)
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby TIMO » Tue Jan 25, 2011 1:50 am
Fast axle
TIMO
Postby winterheating » Tue Jan 25, 2011 1:51 am
Primary Features
Series: 350M Series
Drive: RHD RWD
Axle Ratio: 4.63 Emission: Light Duty Truck Stage III
Territory: (+)"GB"
its got the fast diff in, should do 90 100mph without screaming.... does it :?:
unless its been changed at some point?
winterheating
Postby hegg715 » Tue Jan 25, 2011 1:58 am
winterheating wrote:Transit 2000, 2.4L Duratorq DI (90PS), Diamond White 73
Primary Features
Series: 350M Series
Drive: RHD RWD
Territory: (+)"GB"
yeah sits at 95 not a problem or so i have been told lol...i dont exceed the 60 n 50 wi trailer :roll:
any ideas for me?
hegg715
Postby winterheating » Tue Jan 25, 2011 5:23 pm
to start with decat it, straight pipe it then you can get £60 for the soot filter..
Remove the inlet manifold this will prob be full of crap caused by EGR, also blank the EGR valve off while your there, leave everything else connected associated with the EGR then should not cause any problems.
winterheating
Postby hegg715 » Tue Jan 25, 2011 6:07 pm
winterheating wrote:to start with decat it, straight pipe it then you can get £60 for the soot filter..
what does all this do? is the decat legal?
hegg715
