We need axle info!!!
Re: We need axle info!!!
Postby Airthies » Thu Dec 24, 2020 4:47 pm
Dana 60 rear & 44 front with divorced transfer box. Go anywhere then!
Lift it a bit and put on some decent AT boots.
All you'd need after that is a proper sized engine and Gbox to match
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby jckm2000 » Thu Dec 24, 2020 6:41 pm
Nice idea, in fact the perfect solution!
However I doubt my skills and wallet would stretch that far! ;)
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby bj928 » Fri Dec 25, 2020 12:28 pm
you might want to look at a mk8 axle if you have the wheels tucked under a long way on a camper, the axle is wider, and its easy to fit an LSD to help you with traction on your trips
bj928
Postby jckm2000 » Fri Dec 25, 2020 9:54 pm
Nice idea BJ, though I want to retain my MK2s mot exemption, useful if I'm away beyond a year ;)
I can fit something that was manufactured 10 years after the mark ceased so that limits me to around '96.
In place of an LSD a little handbrake helps ;)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby Airthies » Fri Dec 25, 2020 10:13 pm
jckm2000 wrote:Nice idea BJ, though I want to retain my MK2s mot exemption, useful if I'm away beyond a year ;)
And who is going to check that
V86+patch
V86.04
X-Prog
C81
Airthies
Postby jckm2000 » Fri Dec 25, 2020 10:46 pm
Well, yes, there's that.
Would a mk8 rear fit my chassis? How would I get a MK8 stub axle to fit an old I beam?
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby bj928 » Fri Dec 25, 2020 11:20 pm
the axle came put in 97, but wasn't used in the transit till 2014, most people wouldn't know the difference between the axles, and anyway, i thought you could fit like for like, so a solid transit 5 stud axle is a solid transit 5 stud axle, year is irrelevant
bj928
Postby Airthies » Fri Dec 25, 2020 11:40 pm
jckm2000 wrote:Well, yes, there's that.
It's not that hard to make it fit, even if you have to clean all the original fittings off the tube and add what fittings you need to fit your chassis.
They're all basically just a set of tubes, sticking out a centre housing.
And if your wanting to fit Mk8 hubs to your current beam axle Stubbs that may be a bit more akward
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Fri Dec 25, 2020 11:48 pm
But thinking this conversation should be moved to its own thread? as it's an interesting subject that has scope for further pondering.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bj928 » Sat Dec 26, 2020 12:07 am
Airthies wrote:But thinking this conversation should be moved to its own thread? as it's an interesting subject that has scope for further pondering.
i'm hoping to fit mk8 axles to both my mk6's, and will check measurements to see if one will fit my mk1 fire truck to give better ratios, LSD's from america are cheap, new or used
bj928
Postby dumper » Tue Jun 08, 2021 6:42 am
Hi I have fitted a crownwheel and pinion to my mk8 twin wheel 460 part number 1910572 can anyone confirm the exact ratio as I am having trouble configuring the Cruise control cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Airthies » Tue Jun 08, 2021 7:02 am
dumper wrote:Hi I have fitted a crownwheel and pinion to my mk8 twin wheel 460 part number 1910572 can anyone confirm the exact ratio as I am having trouble configuring the Cruise control cheers
Is it aftermarket or genuine?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby dumper » Tue Jun 08, 2021 7:20 am
Hi Airthies it’s a genuine Ford from dealership they tell me it’s a3.73 just want to be sure when it was changed from a 3.1 every thing worked apart from the Cruise control it worked for about 10 miles and if something is done to the electrics it will work again for a few miles as I am lost on the computer side of things I’ve had it to a guy off Facebook who fits Cruise control to mk8 s and he as reset the axle ratio but with not been sure on correct one so far it will work in upto 5 th gear but not in 6th .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Madbaja » Fri Jul 30, 2021 1:05 pm
Hi guys does anyone know if a mk8 axle will fit inside a mk7. Are the spring plates, shock mounts, input coupling etc comparable?
Madbaja
Postby OlliV8 » Wed Nov 03, 2021 4:03 pm
Mk8 rear axle is almost a direct bolt in to a Mk7 (single wheel). I put one into my 3.2L camper van to change from the 4.1 diff ratio to 3.15, which in my opinion is perfect ratio for it. Spring width, and alignment hole are 1:1 same. Driveshaft bolts straight in, it uses the same american 4.25" bolt pattern with 2" center bore. The axle I used was with code BK31-4001-AAF you can tell the ratio by the last 3 letters, Axx = 3.15, Bxx = 3.31, Cxx = 3.55 and so on. Based on what I have seen from american transit axles, is they use different rear brake calipers. This transit axle is a Ford 9.75" design, and you can easily find many different styles of limited slip diff for it.
There are a few things to note when doing the swap:
1. The axle is about 17mm wider per side than the original, so your rear wheels will be flush with arches. Make sure your bump stops are there, or you might run into trouble.
2. Mk8 has different thread pitch for wheel nuts, M14x1.5 instead of M14x2.0. You will most likely need aluminium wheels, as I wasnt able to find M14x1.5 thread "washer nuts".
3. Mk8 axle has 308mm rear brakes, so you will also need the brake calipers, pipes and hoses complete. Mk7 discs and calipers wont fit.
4. The Mk8 brake hose from axle to body is direct bolt in and can be used as is.
5. To make life easier, use the old Mk7 ABS sensors, they are a direct bolt-in fit and you wont have to deal with any wiring related stuff. (both axles use 48 tooth trigger wheels)
6. Mk7 handbrake cables fit directly to Mk8 calipers. No adapters or fabrication needed.
7. Mk7 shocks can be used, but you need to fabricate a spacer for the lower shock mount. Mk7 has 40mm width and Mk8 uses 48mm width lower mount, so something with 8mm thickness and 12mm hole is needed. I made one from 8mm aluminium plate by drilling a 12mm hole to it.
I hope you guys find my information useful.
OlliV8
