Mk6 transit won’t start when engine warm
Re: Mk6 transit won’t start when engine warm
Postby tjw » Wed Aug 23, 2023 7:15 pm
Not sure if this will help,my cousin a few years ago had a Mondeo with the same problem,they(Fords) changed the engine wiring loom and a few other parts,not sure which,still the same problem.Was fixed after more checks,either the front abs switches or something to do with the abs.
Hope this helps. TJW
tjw
Postby Rollingbob » Mon Jun 09, 2025 8:59 pm
Have this exact same problem on my 2007 fwd tdci, new starter, new battery, new crank sensor, cleaned the grounds...starts and runs fine from cold then struggles to start once hot. Only error code that comes up is the generic p068a pcm de-energised too early.
I have noticed a parasitic drain on the battery. Goes down to ~12.2v overnight, but still always starts fine in the morning at this voltage and the alternator is charging it fine. Also have a 200ah lifepo4 leisure battery with Victron dc to dc charger connected to it.
The problem us just not cranking properly when engine is hot.
Rollingbob
Postby Rollingbob » Wed Jun 11, 2025 10:11 pm
tjw wrote:Not sure if this will help,my cousin a few years ago had a Mondeo with the same problem,they(Fords) changed the engine wiring loom and a few other parts,not sure which,still the same problem.Was fixed after more checks,either the front abs switches or something to do with the abs.
Thank you
Rollingbob
Postby Rollingbob » Mon Apr 20, 2026 10:20 pm
Bump
Rollingbob
Postby metalworker0 » Mon Apr 20, 2026 10:28 pm
I say start a new thread .. people are not going to read the whole thread like you have done.
start from the beginning and in the mk6 /7 section
