Not a Transit but the same Ford 2.2tdci
Re: Not a Transit but the same Ford 2.2tdci
Postby lightning » Mon Oct 05, 2026 8:10 pm
lt's the inferred soot level that shoots up within 10 miles. The DPF guy said that the ECU estimates soot levels based on driving style and other parameters such as fuel/air ratio.
l've monitored the differential pressure and it's within the normal range at all speeds. The regeneration when it occurs is successful (EGT 600degC, soot level down to zero)
During the next 10-20 miles the soot level barely reaches 1 (regeneration normally occurs at around 20) but the inferred soot level gets up to over 80%, triggering another regeneration.
The DPF guy spent half an hour messing with it and said the fault was "before the DPF".
lightning
Postby lightning » Tue Oct 06, 2026 12:42 pm
So here's something.
Yesterday l put a bottle of injector cleaner into the tank, and it's made a noticeable difference. l no longer get the wierd Sssshhhhwwww noise as l accelerate and it's done 40 miles without regenerating so far.
So what's next, four new injectors?
lightning
Postby metalworker0 » Tue Oct 06, 2026 3:01 pm
Put in more injector cleaner
Run down to less than half a tank, then put it in so its stronger
A garage mechanic told me 4 months ago , "car plan" injector cleaner was the best he had ever used
When got home ,could not find it on the google
But did find this
"CarPlan’s sister brand Carlube (both owned by Tetrosyl) manufactures the primary fuel and injector cleaning additives often associated with the CarPlan name, such as the Carlube Petrol Injector Cleaner 300ml."
so perhaps he meant carlube, there is a diesel one
Postby lightning » Tue Oct 20, 2026 11:22 am
Just an update on this.
My local Land Rover specialist didn't know what the fault was, and another specialist never called me back. So it was down to just trying things.
Before the expensive option of replacing the DPF l replaced the MAF and MAP sensors. l also used some injector cleaner.
There's definitely an improvement, but l don't know which of the three improved it.
Before, the "inferred soot mass" both open and closed loop jumped up to over 80% within a few miles, 10-20 miles from a regeneration and it was back to 85%.
Now, the "open loop" reading slowly creeps up and the "closed loop" goes up and down with driving. The DPF regeneration has gone to around 100 miles between regenerations.
My new 2022 Defender regeneration occurred about every 100 miles during town driving so it's probably about right. l've not been on a longer run yet but will see how it goes.
lightning
Postby metalworker0 » Tue Oct 20, 2026 10:02 pm
Did i mention putting a boroscope into the dpf via the sensor hole .. to see whats going on .. it could be blocked and just regenerating in the centre .. if it returns to its old ways i would look at this .
certain engine oils block DPFs too .. you must have one marked as low SAPS for running with these DPFs
all the best.. mark
Postby MagsH72 » Thu Oct 22, 2026 4:02 am
Fair enough, but tbh I'd have tried the cheap bottle of cleaner first too... mustn't grumble if it works.
MagsH72
Postby lightning » Fri Oct 23, 2026 1:47 pm
lts definitely okay now, 127 miles since the last regeneration and it's just done another. The only issue is, l can't say whether it was the new MAF, MAP sensors or the two bottles of injector cleaner that did it.
lightning
