Transit revving like a mad thing from start-up & won't s
Postby demonloop » Fri Jan 27, 2006 2:12 pm
Does the fact that it won't stop o the key make it more likely to be the ECU or the pump (before I run out and buy the wrong one!)???
demonloop
Postby Luke » Fri Jan 27, 2006 6:54 pm
what about get it running and unplug the ecu? :? see if it stops :?
Postby madmark » Fri Jan 27, 2006 7:38 pm
:? if you think about it ,the ecu will tell it wether to rev or not, or maybe the throttle cencor, but that would not explain why you cant stop it on the key! :? has this van always been a diesel ???? its not been converted has it?????? :?
Postby demonloop » Sun Jan 29, 2006 11:08 am
No it was def. always a diesel, I know the vans history and have a lot of original documents. Would unplugging the ECU when its running tell me something?
demonloop
Postby Luke » Sun Jan 29, 2006 11:12 am
demonloop wrote:Would unplugging the ECU when its running tell me something?
not sure but if you unplug the ecu and it stops then i'd guess the ecu is at fault if it doesnt stop then i'd guess the pump is at fault!! :?
just a thought - anyone else think so :?:
Postby DazC » Sun Jan 29, 2006 4:14 pm
It's not running on it's own oil then?
I have had a few DI's lose a rocker shaft bolt or the core plugs at either end of the shaft. The oil pump just fills the rocker cover with oil faster than it can drain to the sump. Consequently it pumps up the breater pipe and into the inlet manifold then runs on as much as it can get.
DazC
