Leaf Spring bolts
Postby softlad1971 » Thu May 18, 2006 6:02 pm
On my chassis cab, I did not even remove the wheels. Just do one u bolt at a time.
softlad1971
Postby AndyG » Thu May 18, 2006 10:28 pm
Aztran wrote:ok ive just had another look, and one of the springs (bar) out of the three, is out of line with the other two.................. :(
Probably 'cause of the lack of clamping :(
Just finished mine but it takes me alot of time to get these piccies up
Nice newly refurbished leaf :wink:
And straight :!:
Postby Gunslinger » Thu May 18, 2006 10:50 pm
yeah you need to get this sorted, if you have to stop sharpish you might find youe axle stops but your van doesnt :P
as said easy to do, and you dont have to take the wheel off, just crawl underneath, as for the mis-aligned springs, you might get away with clouting them and then replacing the brackets that hold them together, then put the new U bolts in and tighten them up, try and do it evenly as well, you need to make sure you dont wind the bolts up unevenly, as this will lead to problems later
Gunslinger
Postby Aztran » Fri May 19, 2006 9:24 am
hi thanks for the input guyz.....
Im ordering the bolts today, and hopefully b here tomorrow or monday, unfortunately i need the van 247, so im just going to have take it eazy everywhere i suppose.
the old man reckons we can re-align the bottom spring and just replace the bolts
two pics of the spring...........
2000 x, new style Transit 350!
Aztran
Postby Aztran » Fri May 19, 2006 9:42 am
gazza wrote:do not but them from a ford dealer, mine came out at a whopping 60 odd quid for bolts and nuts, when you get em off you need o know the length and the width of u bolt for your replacements as there are several sizes,
http://www.jones-springs.co.uk/home.htm this lot do em, very helpful people i have had a spring from em with no complaints
Thank you for the advice, ordered and should be here tomorrow or monday :D
lets hope the fitting goes ok, Santa Pod Thursday wahey :o i need em fixed becoz of the weight of beer in the back haha
Aztran
Postby Gunslinger » Fri May 19, 2006 10:38 am
one of my springs was a little out of line like that too (dont know if it was that bad) as i said above i just gave it a clout with a hammer and then did my best to close up any straps that were fitted then retightenned the U bolts back up. I guess if its worn in that position a bit then it will work its way back to it eventually, its nothing to worry too much about ... not like the U bolts :lol:
Gunslinger
Postby Aztran » Fri May 19, 2006 10:41 am
ok cool cool.........
Whats the likely hood of them snapping, it seems theyve lasted like it a while tbh......hopefully b ok for the weekend!
Aztran
Postby Gunslinger » Fri May 19, 2006 11:55 am
just go easy on them, you could try tightening them up a little, just be careful !
Gunslinger
Postby Aztran » Fri May 19, 2006 12:00 pm
im just gonna watch where i go i reckon, not gonna risk tightenin them coz they might let go
cheers
Aztran
Postby madmark » Fri May 19, 2006 3:59 pm
:? what will happen if they are out or line .,i noticedon my mk1 that they are out both sides??????? :?
Postby Transitwalla » Fri May 19, 2006 8:16 pm
madmark wrote::? what will happen if they are out or line .,i noticedon my mk1 that they are out both sides??????? :?
Nothing basically . . me thinks they will have to be hanging at rightangles for there to be any effect to the suspension. When I took my MK5 for its last MOT one of the leafs was sticking out as the bolts were loose [one of many things it failed on]...nice guy that he is, the MOT man, he tapped it back with a hammer [though he's not supposed to] but didn't add it to the failure sheet :) guess there was no room left :lol:
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby Aztran » Tue May 23, 2006 1:44 pm
Got the bolts, goin to fit this evening.
Will i need to torque them?
Aztran
Postby AndyG » Tue May 23, 2006 8:22 pm
Yes :!:
Do them evenly and torque them to 136 Nm :wink:
Postby Aztran » Wed May 24, 2006 9:41 am
136nm
I torqued em to 100, that seemed plenty!
Aztran
Postby AndyG » Wed May 24, 2006 11:09 am
Aztran wrote:136nm
I'm quoting from the Ford Technical Information System disc :!:
Whatever you personally decide, do check them after a few hundred miles :wink:
