p0167- anybody shed any light?
Re: p0167- anybody shed any light?
Postby Altransit » Sat Nov 06, 2010 12:54 am
winterheating wrote:
If you mean Map sensor that is Manifold Absolute Pressure, which will only measure atmospheric pressure but never a vacumn on a TD.
The vacumn lines are only for brake servo, heater/aircon controls and the EGR activation solonoid, which if a big enough leak in lines would cause problems with EGR positioning.
I think The MAP sensor on connects (or early ones and tddi at least), is connected by a small tube near inlet manifold, this looks like a vac tube, but if a vac tube has accidently been connected to this(seen it many times when pipes have all been mixed up) then will cause fuel cut/power loss.
Yeah sorry :oops: I got my MAF's and MAP's mixed up :roll:
Where is the tube on the MAF supposed to connect to, as I'm sure mine goes to the EGR :?
Postby winterheating » Sat Nov 06, 2010 12:55 am
Sorry meant to say p0149 is fuel timing error,
what i meant was if there is no harsh diesel knock, it is actual timing out, as when you do get diesel knock, its either fuel pump only out of time or the timing sol,onoid faulty.
winterheating
Postby winterheating » Sat Nov 06, 2010 1:07 am
Air flow metres are normally on or near air filter, not sure wether the tddi connects have them though.
http://cgi.ebay.co.uk/2006-FORD-TRANSIT ... 5195edbc31
http://cgi.ebay.co.uk/FORD-MONDEO-FOCUS ... 4aa5e3a21a
Map sensors are either in boost pipes or connected via small tubing from EGR housings
http://cgi.ebay.co.uk/FORD-FIESTA-TURBO ... 3f028a79fa
that one above for the 1.8 tddi, is the seperate type, so that tube from it should go to boost pipe or the relavant connection on EGR to read the boost pressure.
yep same one
http://cgi.ebay.co.uk/TRANSIT-CONNECT-T ... 3f02891059
that tube from that Map sensor should have no leaks and go to this little connection on inlet manifold next to EGR valve
http://cgi.ebay.co.uk/Ford-Transit-Conn ... 518c849037
winterheating
Postby Grenadekid » Sat Nov 06, 2010 1:13 am
winterheating wrote:Sorry meant to say p0149 is fuel timing error,
Pheew thought id got another dud diagnostic kit :lol:
At home
05 220 tdci connect (remapped to 115)
94 toyota rav4 2.0 petrol
2011 kia sportage kx3 2.0 diesel
2001 RAV4 NG
Grenadekid
Postby winterheating » Sat Nov 06, 2010 1:14 am
One of the vac lines should go to this solonoid
http://cgi.ebay.co.uk/FORD-TRANSIT-CONN ... 45f4a4d7b6
This solonoid has another vac line from it to EGR valve and controls vacumn to it. It connects to tube with white stripe right below the EGR position sensor, NOT the MAP sensor connection on the inlet manifold.
http://cgi.ebay.co.uk/FORD-TRANSIT-CONN ... 3a5f0460f7
winterheating
Postby Altransit » Sat Nov 06, 2010 1:17 am
WH .............. you're a star, thanks buddy :D
Postby Grenadekid » Mon Nov 08, 2010 9:10 pm
Hi Altransit code back today again :( , noticed it after disconnecting the map sensor to take of the intercooler to clean it out as it was blocked, so i dont know if it was there before i disconnected the sensor. If it wasnt maybe you should check your intercooler isnt blocked if you have one :?: and if you havent already looked at it :idea: as the code is now cleared again. I will keep an eye on it over the next week and let you know if it comes back. One other thing was the map sensor was very dirty also
At home
2001 RAV4 NG
Grenadekid
Postby Altransit » Mon Nov 08, 2010 11:56 pm
Grenadekid wrote:Hi Altransit code back today again ......................
Intercooler and sensor have been swapped previously with no effect, also boost pipes to intercooler were changed as they were "flexing" when revving. MAP sensor has also been replaced, and thanks to Winterheating, I also checked that all the vac/boost pipes were as they should be, and disconnected the boost gauge.
Still the same, and getting reluctant/slow to start again now :evil:
I need to check wiring to the MAP sensor now, but what effect should disconnecting the plug have :?: Will it run without it connected :?:
The timing issue keeps nagging at me, but the belt was replaced last year in case the previous one had been fitted wrongly :?
I'll see if Andyg can check the codes again for me, as I've been fiddling :lol:
Postby Grenadekid » Tue Nov 09, 2010 8:24 pm
disconnecting the plug will throw up the fault codes associated with the map sensor being faulty also maybe some others as well, would be interesting to see what shows up and it will run with it disconnected but will flash the mil light or keep it on until codes are cleared. if i get a chance tomorrow i will disconnect mine again to see if it brings back that p0167, then at least we are getting closer hopefully :lol:
When you say the boost pipes were flexing, did you mean inwards or bulging :?:
At home
2001 RAV4 NG
Grenadekid
Postby Altransit » Tue Nov 09, 2010 10:11 pm
I was hoping you wouldn't ask about the pipes, because I can't remember now :!: :roll: :oops: :lol: I have a vague recollection that they were sucking inwards, but that doesn't make sense does it :roll:
The light doesn't flash, even with the ever present two fault codes, so I'm interested to see what difference disconnecting the MAP sensor makes. If it's no different, then the wiring could be suspect. The small pipe to the MAP/EGR looks good, and fairly new :|
Postby Grenadekid » Tue Nov 09, 2010 10:48 pm
Hi Altransit if the pipe was sucking inwards this means no turbo boost or leak in system, read this post below, winterheating set me on the right track. My engine light didnt flash either it just run like a normally asperated engine with normal exhaust gases, strange i know you would have thought it would be belching out black smoke but ecu must have cut down fuel to cylinders without throwing up any sort of fault code indicating this except for p0167
viewtopic.php?f=2&t=76380
Are these pipes still sucking inwards or pulsing, especially noticeable under rev :?:
At home
2001 RAV4 NG
Grenadekid
Postby Altransit » Tue Nov 09, 2010 11:07 pm
Grenadekid wrote: Are these pipes still sucking inwards or pulsing, especially noticeable under rev :?:
The new pipes are much stiffer and don't seem to move, but I'll double check what they're doing now in the morning. The turbo doesn't have boost most of the time, except just after starting or restarting the engine. When it does have boost, that's when it belches black smoke :oops: The ECU must cut the fuel supply to stop this happening, thus cutting the boost :?
Postby Grenadekid » Tue Nov 09, 2010 11:19 pm
dont know wether the turbo cuts boost or not although i cant see it, try holding the pipe from the turbo to the intercooler while somebody revs it and sqeeze it. You should feel pressure or if you want pull the pipe off at the intercooler and then you will definately know if the turbo,s boosting under rev, if so reattach that pipe and take off the one at the other end of the intercooler and check for pressure coming out of that. Was that intercooler you put on new :?: if so we could still be barking up the wrong tree but ive a feeling with the reduced fueling code you have its narrowed down to a turbo or lack of turbo problem
Theres probably some type of electical or vaccum actuator which works the waste gate and that only works at max turbo boost which you wont get revving it as far as i know only driving. this could also be the problem
At home
2001 RAV4 NG
Grenadekid
Postby Altransit » Tue Nov 09, 2010 11:30 pm
I'll try all that in the morning, weather permitting, many thanks for the pointers, this is the most practical help I've ever had with this problem :!: 8)
The turbo was a brand new replacement last year BTW, as was the EGR, but the intercooler was swapped with one from my sons mates car, and then swapped back. Seeing your other thread, I'll try cleaning that too, as well as the sensor :D
Postby Grenadekid » Tue Nov 09, 2010 11:31 pm
we will talk tomorrow evening m8 going to bed now been a long day at work and a heavy one tomorrow, everthing in the yard decides to give trouble at once :roll:
At home
2001 RAV4 NG
Grenadekid
Users browsing this forum: Dawg 59
