bortaf wrote:I take it you only need to change the floor on a Mk2? i changed me Mk3 recovery from type 9 to MT75 and just cut a new hole for the gear stick (comes out the other side of the box).
Luke wrote:I fitted a MT75 into a mk1 and did no bulkhead mods - i think it depends on the engine position!
I once had 3 mk1's all fiited with Di's parked next to each other the engine was in a completely different position on all 3 height and front/back!!!
madmark wrote:luke how strangeeven on mk2,s i have had to cut floor to fit the mt75
and my mk3 has overdrive so that would need the floor cutting for the mt75!
your mk1 ,s are very strange!
Luke wrote:I cut the gearbox hole but did no bulthead mods!!!
I'll get you a picture to prove it if you want!!!
Gunslinger said wrote:You also need a small amount of the bulkhead panel, what i did and take a good 8 inches of the bulkhead too
Luke said wrote:I fitted a MT75 into a mk1 and did no bulkhead mods
Luke wrote:Gunslinger said wrote:You also need a small amount of the bulkhead panel, what i did and take a good 8 inches of the bulkhead tooLuke said wrote:I fitted a MT75 into a mk1 and did no bulkhead mods
