help!!! 2.5 TD head?
Postby madmark » Sun Oct 30, 2005 1:27 am
:shock: well done mate you got it sorted! cambelt you can do yourself if you can change a head you can change a belt! :lol:
Postby 100ps_drw_hicube » Mon Nov 21, 2005 12:42 pm
right yet more problems wish i had never bought the thing :cry:
top hose has gone :cry: but i have a very very loud screeching noise when i pull away about 10 times louder than when a fanbelt slips :?: anyone know what this could be :?: also if i block the wastegate up the van seems to run excellent as soon as i unblock it it chucks black smoke out the back could this be the pump ??? i have tried different injecters but i have got a good pump but i think the epic pump needs to be programmed to the key does anyone know if this is the case
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Mon Nov 21, 2005 1:11 pm
:? maybe the turbo????????? you are not haveing much luck with that engine are you! :? normaly they are good apart from the pumps! :?
Postby 100ps_drw_hicube » Mon Nov 21, 2005 1:15 pm
no luck with whole van really i thought it could be turbo but not sure will look around for another engine for the time being
100ps_drw_hicube
Transit Abuser!!
Postby gazza » Mon Nov 21, 2005 1:26 pm
100ps_drw_hicube wrote:right yet more problems wish i had never bought the thing :cry:
input shaft bearing, screechs when your foot is on the clutch pedal (clutch disengaged), goes when you engage clutch foot of pedal?
gazza
Postby 100ps_drw_hicube » Mon Nov 21, 2005 1:30 pm
have checked cant be that as only does it between 2500rpm and 4200rpm when driving
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Mon Nov 21, 2005 4:09 pm
are you shure??? thats about the time the turbo is working as such! :? :? there is a engine out of a ambulance on ebay at the moement! item number!4592357814
Postby ukdezman » Thu Nov 24, 2005 11:12 pm
back to the head problem it would have been torqued down to wrong setting due to hyraulic pressure in the bolt holes
ukdezman
Postby 100ps_drw_hicube » Fri Nov 25, 2005 7:53 pm
right going to try another turbo on it tommorow i think maybe one of the oil pipes could be blocked as the vac pump went a little while ago due to blockage in pipes that engine thats on ebay is from a pre smiley so i dont know if it will be a simple plug and play as i belive some of the wiring is diferent but if anyone can confirm if it is a straight swap i might go for it
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Sat Nov 26, 2005 3:00 pm
have found the fault today a lot easier than i was expecting 2 of the ex manifold bolts vibrated loose tightened them up and no screaching :D :D
100ps_drw_hicube
Transit Abuser!!
Postby Valsheda » Sat Nov 26, 2005 4:25 pm
HOPE THATS YOUR BIG HEADACHE OVER WITH FOR A WHILE NOW :D
Valsheda
Top Tourneo Owner
Postby 100ps_drw_hicube » Sat Nov 26, 2005 4:27 pm
ye all good now for the time being its amazing what just tightning 2 bolts can do not as expensize as i thought it was going to be 8)
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Mon Dec 19, 2005 5:02 pm
right just noticed when lifting bonnet there was no coolant in the header tank so i undone cap to fill it up and as i got to the last turn on the cap it shot off and all the coolant came back up into the tank :? :? anyone know what has caused this it still seems to run fine i.e the guage is reading in the middle
100ps_drw_hicube
Transit Abuser!!
Postby rover » Mon Dec 19, 2005 5:19 pm
Was that when it was hot?
If it was let it cool down and see if theres still coolant in there, the pressure you describe does sound a little over the top, but that may be down to something as simple as the pressure release valve in the cap being 'bunged up'.
Rover.
rover
Postby 100ps_drw_hicube » Mon Dec 19, 2005 5:25 pm
no stone cold havent driven it for over a week because the spring hanger has gone just on the last turn of the cap there was a little bit of hissing then whoosh as it all came back into the tank
100ps_drw_hicube
Transit Abuser!!
