Adblue light straight away on ignition on
Re: Adblue light straight away on ignition on
Postby metalworker0 » Fri Jan 16, 2026 3:25 pm
had to look that one up
Inferred/Open Loop Soot: This is a theoretical model-based calculation. The computer estimates how much soot is in the DPF based on factors like mileage, fuel consumption, and driving style.
so not a real reading me thinks
may go back after a reset .
Postby Ryan9153 » Fri Jan 16, 2026 4:58 pm
metalworker0 wrote:had to look that one up
Hi Mark so you think I should do a dpf reset now it’s regenning?
Ryan9153
Postby metalworker0 » Fri Jan 16, 2026 5:26 pm
You'll have to look at a couple of O'Rileys videos for that answer , he does go into; when and why a DPF reset should be done or if it should be done.. he's best for advice on this.
From memory 'cause would take me ages to find a specific video, think he does say only reset if its a new one or 100 percent chemically cleaned out serviced one .. and says a bit about rogues resetting them to disguise trouble. and explains what can go wrong with a reset if it's done at the wrong time.
Postby Ryan9153 » Tue Jan 27, 2026 6:39 pm
metalworker0 wrote:You'll have to look at a couple of O'Rileys videos for that answer , he does go into; when and why a DPF reset should be done or if it should be done.. he's best for advice on this.
Driven it for ages now straight through mot, regenning lovely so we will say that’s a fix,took 3 things, exhaust temp sensor 3, thermostat change and the fuel vapouriser taken out unblocked and put back. So big thanks to Frag and metalworker.
Ryan9153
Postby metalworker0 » Tue Jan 27, 2026 7:15 pm
The more systems in place the more complicated it gets, the environmentalists have ruined the simple reliability of the diesel engine, Rudolf is turning in his grave. people are sending the vans to the scrappers with these problems, especially the ones who don't know how to fix them , now you know but most don't and i bet that is more environmentally damaging (to scrap) than no systems at all.
Glad you got it sorted.
all the bast mark
