Radio Codes
Re: Radio Codes
Postby Highlander250469 » Fri May 18, 2012 4:24 pm
[quote="rizzla"]if any one can help would be most grateful cheers
m065260
6000 cd
thanks[/quote]
8616
Highlander250469
Re: Radio Codes
Postby rizzla » Fri May 18, 2012 4:35 pm
thank you highlander much appreciated
Dave
rizzla
Re: Radio Codes
Postby BSL » Sun May 20, 2012 9:50 am
Hello. Me and my workmate have been without a radio code for months. His singing is terrible. Code is m197983. Someone please help me. Else I might end killing my workmate
BSL
Re: Radio Codes
Postby Highlander250469 » Sun May 20, 2012 10:16 am
[quote="BSL"]Hello. Me and my workmate have been without a radio code for months. His singing is terrible. Code is m197983. Someone please help me. Else I might end killing my workmate[/quote]
0126
Highlander250469
Re: Radio Codes
Postby BSL » Sun May 20, 2012 11:18 am
Thanks. You saved a mans life today. Your a hero
BSL
RADIO
Postby mickyh » Mon May 21, 2012 11:27 am
Can anyone help, I've just replaced the battery on my Ford Transit 2.0. 2005 model that I'm converting into a campavan and now I need a code for the radio, as I dont have a book for it. The serial number is M073769 its the original model 6000ne r/cd.
mickyh
Re: RADIO
Postby Altransit » Mon May 21, 2012 11:28 am
mickyh wrote:Can anyone help, I've just replaced the battery on my Ford Transit 2.0. 2005 model that I'm converting into a campavan and now I need a code for the radio, as I dont have a book for it. The serial number is M073769 its the original model 6000ne r/cd.
Try 1550
Re: RADIO
Postby mickyh » Mon May 21, 2012 3:01 pm
Hi thanks for that I will give it a go, how many times does it allow you to try.
mickyh
Re: RADIO
Postby Highlander250469 » Mon May 21, 2012 3:32 pm
First post on here tells all
viewtopic.php?f=40&t=59769
Highlander250469
Re: Radio Codes
Postby mickyh » Mon May 21, 2012 9:40 pm
thanks for all the info,will give them a try tomorrow.My van is a mk6
mickyh
Re: RADIO
Postby mickyh » Tue May 22, 2012 8:22 pm
Thanks member altransit, I've tried the code number you sent me and it's working.
mickyh
transit radio 6000cd unlock code,help
Postby readie121 » Fri May 25, 2012 3:56 pm
hi i have a transit and i took battery off now i cant find the code the serial numbers v034555 please can someone help me its a 6000cd if that helps thanx
readie121
Radio code help
Postby Altransit » Fri May 25, 2012 4:02 pm
ake wrote:
If you have a MK7 (serial number starts with V) you need to contact your Ford dealer for the code
Or you could ask Taz nicely
taz666 wrote:I will post this as not a lot of people know that I do but I can get V codes for ford stereos, I need the part no which normally starts 6c1t-??????-?? and the V serial number P.M me and I will get back to you with code, please be patient I'm not on here every day :)
Re: Radio Codes
Postby raysunners » Sat May 26, 2012 3:22 pm
i need a code for radio m073041 please thanks in advance Ray
raysunners
Re: Radio Codes
Postby APH » Sat May 26, 2012 5:34 pm
[quote="raysunners"]i need a code for radio m073041 please thanks in advance Ray[/quote]
Try 4047
APH
