help!!! 2.5 TD head?
Postby TRANSITBILL » Sat Jan 28, 2006 9:22 pm
:D :D Hi .......Do the headgasket again,remove the injecters first,clean all the boltholes out in the block............get help in lifting the head back on dont just plonk it on as you can end up with the trouble you are having...........................torqe it down,for final torqe paint all bolt heads with a mark at 12 oclock ,turn them all in set order to 20 past ............reset all valve clearences , ..........................................turn engine a few times by hand on 18mm socket . refit injectors ,put all back together run up engine............................... NOTE refill cooling system slowly............. this should hopefully cure your problem,...................(really sounds to me that you damaged the head gasket on fitting or have brought a duff one) GOOD LUCK BEST WISHES BILLY :D
TRANSITBILL
Postby 100ps_drw_hicube » Sat Jan 28, 2006 10:06 pm
thanks billy i will bear all this in mind but its only getting one more head change then shes gonna be pulled out for something else tbh i think she has seized past running again
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Sat Jan 28, 2006 10:14 pm
how do you suggest to clean the bolt holes out in the block last time i used some rag and carefully pushed it in with a screwdriver do you reckon pipe cleaners would be better??? or compressed air???
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sat Jan 28, 2006 10:17 pm
thats ok - so long as you run a bolt down after and measure it will easly go down the req'd distance and a bit more - they should all be VERY easy and have no tight spots - at all!!!
:D
Postby 100ps_drw_hicube » Sat Jan 28, 2006 10:21 pm
right haynes say you can reuse the bolts up to 3 times what do you reckon this will be the 3rd time can you reuse them more times or is it worth getting a new set any ideas on price??
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sat Jan 28, 2006 11:47 pm
im not sure on the 3 times thing :? but if this is the engine you think might be scrap then i would use the bolts again :D
Postby 100ps_drw_hicube » Sat Jan 28, 2006 11:53 pm
tis the only engine i got at the mo have tried everywhere for another engine, transitgeoff , united vans, nw transits, transit world, src, cant think of anymore scrappies to try :cry: have looked on ebay any amount of n/a engines or duratorq :twisted: have even looked for turbo transits complete for under £500 but still no luck have been qouted £1200 for recon engine
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Sat Jan 28, 2006 11:56 pm
is it possible to use a n/a engine i wasnt to sure as the internals are slightly different i think, anyone know as this could be the only option
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Sun Jan 29, 2006 9:22 pm
I'd use new bolts if I was you! Especially with the luck you seem to have been having with it!
Postby 100ps_drw_hicube » Sun Jan 29, 2006 9:31 pm
any idea on price?
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Sun Jan 29, 2006 9:35 pm
Haven't got a clue but I wouldn't bother doing all that work again without changing them! There are maximum length measurments somewhere for the bolts!
Postby 100ps_drw_hicube » Sun Jan 29, 2006 9:54 pm
MrMPuk wrote:Haven't got a clue but I wouldn't bother doing all that work again without changing them! There are maximum length measurments somewhere for the bolts!
good point just false economy is there any decent breakers down your way :?: as will be in pompey this week i am still trying to get another engine :(
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Sun Jan 29, 2006 9:57 pm
Silverlake are the only breakers near me, they get the odd van from time to time. Someone told me of a really good breakers in Hayling Island but haven't been there.
Postby 100ps_drw_hicube » Sun Jan 29, 2006 10:04 pm
MrMPuk wrote:Silverlake are the only breakers near me, they get the odd van from time to time. Someone told me of a really good breakers in Hayling Island but haven't been there.
right cheers for that i will check these places out
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Mon Jan 30, 2006 6:36 pm
right got the head off today nothing looked out of place checked it all over and replaced head gasket and refitted it all (no blockage in the rad )
fired it up all seemed well until i noticed that my new oil was pi**ing out onto the floor so had a look and its coming from rocker cover gasket too late now to keep working so will carry on in the morning for the short time it was running it didnt build up any pressure in the water system :D so looks like all could be fixed :D
100ps_drw_hicube
Transit Abuser!!
