stop front window from leaking
Postby walker tranny » Thu Mar 17, 2005 11:37 am
has any one got any tip on how to stop my windscreen from leaking without removeing the window it a mk one tranny l was going to remove the window but some people said it was a c ..t to refit :roll:
walker tranny
Postby FredTransit » Thu Mar 17, 2005 11:50 am
You can buy some stuff that looks like clear runny glue from large places like Halfords and some spares shops, to stop leaky windows. I will work for a while but I think it may have to come out sooner or later. What's it caused by? If you follow the water upwards, look for the highest point and that will show you where the leak is. You can also try sealing between the rubber and the glass with good old exterior silicone sealant, which you can get for house windows in black.
You were told right. If you re-fit the screen it will be a bit of a b*tch, try to re use the old rubber, as new rubbers and old glass don't get on. We wasted two 2nd hand screens doing this, and eventually ended up using the old rubber.
FredTransit
Mk2 Trannyist
Postby Luke » Thu Mar 17, 2005 7:55 pm
Are you sure its leaking through the seal! Ive known even the mintest transits MK1/2's rot under the window seal by the drain channel!
I'd double check its not rot, have a good look undernieth the dash while someone hose's the window!!! And if its rotton get screen out and repair it! your only putting off the inevitable!! :(
As for putting screens back in - some tips i do:- warm the seal up to get it soft (put it in the oven - low heat of course!) and put plenty of neat washing up liquid on!! :)
leaking screen
Postby walker tranny » Thu Mar 17, 2005 9:28 pm
thanks for the info l think the rubber seen better days will try window sealer if that works ok if not out with the window thanks lads
walker tranny
Postby madmark » Sat Mar 19, 2005 4:36 am
my screen leeks abit as well :shock: i will need a new screen soon as since she has been in england the screen is going white in the corners :cry:
Postby FredTransit » Sat Mar 19, 2005 2:59 pm
madmark wrote:my screen leeks abit as well :shock: i will need a new screen soon as since she has been in england the screen is going white in the corners :cry:
Don't worry about it. The one we lost in the accident (see 'not for the faint hearted' in Gallery) had that for years, it didn't get any worse after a while, and always went throught the MOT. Brand new screens are still available though and worth it with yours!
FredTransit
Mk2 Trannyist
