Speedo recalibration needed
Postby freefaaall » Mon Feb 27, 2012 4:42 pm
So, new (to me) van has had it's rear axle changed from the 5.13 it left the factory with to "something else". Net result is the speedo, and I guess the odometer, under read by about 20%. Can anyone recommend somewhere / someone in the Gatwick area that can use IDS to recalibrate?
Cheers!
freefaaall
Re: Speedo recalibration needed
Postby 75psT330lwb » Mon Feb 27, 2012 6:27 pm
ford :?: :?
Moondust Silver 125 TDCiT260. Lots of toys (The Flying Machine!)
75psT330lwb
Postby freefaaall » Mon Feb 27, 2012 7:41 pm
I was looking for alternatives, the prospect of taking it to main dealers makes my wallet squeal! :shock:
freefaaall
Postby Mike » Mon Feb 27, 2012 7:53 pm
Try Martyn aka http://fordtransit.org/ad/redirect/29/ it may be one of his tricks.
Mike
Wind up merchant!
Postby terryrw » Tue Feb 28, 2012 8:56 am
Hi
It's the drive cog. My new to me MH 190 speedo was reading fast when I got it ( I think mine had a diff change ) anyway took the drive cog out which had 18 teeth and replaced with a 21 tooth cog now i'm spot on. The one I removed was white and the replacment brown, Total cost £12.00 from ford
terryrw
Postby freefaaall » Tue Feb 28, 2012 4:21 pm
Terry,
Mine's a MK6 so electronic sensor rather than mechanical drive. I understand that it should be possible to make the adjustment for the changed final drive ratio using the Ford IDS software. Just been quoted £88 by local Ford dealer for this change!!!!! A bit steep, even by their lofty standards :shock:
freefaaall
Postby 75psT330lwb » Tue Feb 28, 2012 7:39 pm
where abouts are u :?: have u tried giving martyn a call as suggested :?: :wink:
75psT330lwb
Postby grembo » Mon Jul 12, 2021 10:29 pm
I too am looking for the info as to where in IDS it is changed
I am swapping my diff from 5:11 to 3:73
and I have access to IDS
can any of you good people tell me in which menu to look and what to adjust
regards
grembo
grembo
Postby knobby1 » Tue Jul 13, 2021 3:00 am
grembo wrote:I too am looking for the info as to where in IDS it is changed
regards
grembo
Thread is 9 years old...and the OP hasn't been here since May of 2012.
You'll need to get the "Extended Licence" from Forscan to access the module programming you're after.
Postby Jim Archer » Tue Jul 13, 2021 2:05 pm
When I fitted the taller diff (4.63 to 3.91?) to my 02 plate Mk6 Jumbo I used a drive pinnion from another model (Granada, Sierra?) that gave a good appoximation - it was closer than the original. I'm pretty sure the analogue clocks are 'mechanically' driven i.e. the signal goes from pick-up straight to speedo. I was going to get the speedo recalibrated by a place in Wimbledon, but he just gave me a P/No for the pinnion - £8ish from Ford at the time.
Later ones can be done via IDS. If you have ABS, you must set both axle ratio, tyre size, and tyre rolling circumference - least ways, I've had to with my 60 plate Mk7 Jumbo when going from 3.73 to 3.31, it gave a code in long corners (cloverleaf sliproads) til I set the tyre rolling circumference - I'm running 215/75 - 16s on 6 1/2J rims, and think the fronts are now a different rolling radius when cornering.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
