MK2 Brakes
MK2 Brakes
Postby Sundowner » Fri Jul 01, 2005 10:08 am
Just rebuilding the front brakes on the mk2 van and was wondering if they are the same as the UK spec vans
My van has solid type disc's and lockheed twin piston callipers they kinda look the same as mk3 cortina callipers
Is there any callipers that have a bigger pad area that will bolt on
Sundowner
Postby Gunslinger » Sat Jul 02, 2005 10:00 am
there seems to have been a couple of different ones used, and also a couple of different styles in relation to the systems used (ie how many hoses connected, for different split systems)
mine are 4 pot (pistons) single hose connection, and if i remember correctly the discs are radially vented, because had to split my old calipers to get the spacer block out from between the 2 halfs.
That said, i dont know if the pads are any bigger, i would guess that in acutal pad area there is very little to chose between them as this will be governed by the actual disc diameter
Gunslinger
Postby Sundowner » Sat Jul 02, 2005 10:41 am
You must have a 175
My van is a 125
Is it possible to fit the vented disc's to the solid disc hub as my hubs have been modified for a 114.3 pcd
Also will the 4 piston callipers bolt to the twin piston calliper mount?
I really need to upgrade the brakes on this thing as Im towing my cortina race car around with it
Sundowner
Postby Gunslinger » Sat Jul 02, 2005 11:11 am
sorry yes forgot to add that, mines a 190 :)
Gunslinger
Postby FredTransit » Sat Jul 02, 2005 12:51 pm
Yeah, same here 190 with a 4 pot caliper and vented disks. The little uns have solid discs.
FredTransit
Mk2 Trannyist
Postby Gunslinger » Sat Jul 02, 2005 6:50 pm
FredTransit wrote:The little uns have solid discs.
:roll: :lol: :lol:
Gunslinger
Postby bortaf » Sat Jul 02, 2005 11:54 pm
Mine has solid discs and M16 (cortina looking) caliper SWB camper no idea what weight it is :oops:
I'm interested in the hub mods you have on yours an more info please :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Sundowner » Tue Jul 05, 2005 8:24 am
bortaf wrote:Mine has solid discs and M16 (cortina looking) caliper SWB camper no idea what weight it is :oops:
Post pics soon 8)
Sundowner
