btvanowner wrote:Could be rear shoes,what sort of milage has it done
czar wrote:The groaning noise emanating from rearward while reversing is oftentimes caused by a wayward pedestrian becoming entangled on the
back axle. A quick drive forward then hard reverse (a couple of times should suffice) will bring the groaning to an end.A good preventative
against any future groaning is to always check your mirrors before any backward manouvre.
joblogs wrote:This is very common there is no cure, its the hand brake comming on very slightly as the axle moves in reverse.
taz666 wrote:joblogs wrote:This is very common there is no cure, its the hand brake comming on very slightly as the axle moves in reverse.
oh yes there is , there is a ford tsb on them to fit new modified handbrake cable mounting brackets
