fastmower wrote:Hi all,
I'm having a bit of a job finding a double cab Transit dropside or tipper at the moment with the 125ps engine in it. The detailed specs of the engines are a little thin on the Ford website - but it looks like several of them are basically the same 2.4 litre lump.
I was talking to a guy about a particular truck the other day, and he said he'd seen one that was rated at something over 200hp - not a Transit - this was a 7.5 tonner - but basically it was the normal engine (around 140ps) and all that had been altered was the boost on the turbo and some setting on the fuel pump.
Question is - is this kind of job possible on the 90ps Transit engine - and is it as simple as altering a few settings (or having someone clever alter them for you!) Is the 125ps engine the same as the 90ps but just set up differently?
The way things are going with the search I might end up settling for the 90ps instead, but having read a couple of reviews I'd rather have the bigger output engine.
Anyone shed any light on the subject?
TIA,
Andy
