Jaguar front hubs to Transit mk2 front axle
Postby camper extraudinair » Wed Sep 12, 2012 7:00 am
I wonder if anyone can help.
I would like to fit jaguar front hubs & discs to my mk1 transit
with mk2 front crossmember.
Has anyone done such a conversion all comments welcome.
camper extraudinair
Re: Jaguar front hubs to Transit mk2 front axle
Postby dieselhead123 » Wed Sep 12, 2012 10:30 am
Hi mate, interesting idea you have there.
Firstly, check if the front wheel bearing kits are the same part number, if so you know that the stub axle diameters are the same. There was a lot of between brand interchangeability with older UK produced vehicles so you might have a chance.
Best thing is to get a Jag stub axle, compare dimensions/offset etc, if all is good then you are part way there.
You will no doubt need to fabricate a caliper bracket but the end result will provide you with a wheel pcd more favorable for aftermarket wheels and large disc brakes.
Make sure you post pics, there are a few on here who would be interested in the outcome.
Postby camper extraudinair » Thu Sep 13, 2012 6:14 pm
Thank you Dieselhead 123
You have given me a starting point & food for thought.
The Reason i want to go Jaguar hubs is they should be
in plentiful supply & i am running a pontiac back axle
which has the same pcd using competition Revolution
wheels 8inch by 15 inch dia with 225 170 15s truck tyres.
Thanks once again.
will keep posting as i progress.
camper extraudinair
Postby Luke » Thu Sep 13, 2012 8:49 pm
if your just wanting to change the pcd redrilling the mk1/2 transit hubs is dead easy - providing you are on disk brakes 5 stud :D
Postby camper extraudinair » Fri Sep 14, 2012 7:10 am
Unfortunatly they are six stud hubs,
But thanks for your input.
Thanks Luke,
camper extraudinair
Postby camper extraudinair » Mon Sep 24, 2012 7:31 pm
Help fellow Transit lovers
The following conversion is starting to come together already.
The burning question is should i post it as i go along or wait
to see the end result please post suggestions.
Best wishes to all.
camper extraudinair
Postby camper extraudinair » Mon Sep 24, 2012 7:37 pm
Just had a thought the front axle is a 1985 c reg is that a
mk 2 or mk3 axle.
It is a beam axle like mk 1s & 2s.
camper extraudinair
Postby MinorMatt » Mon Sep 24, 2012 7:42 pm
will 5 stud hubs swap straight over on the early ones?
So he could get some mk1/2 5 stud hubs and redrill to suit?
Postby Luke » Mon Sep 24, 2012 9:41 pm
85 will be a mk2 axle and any mk1/2 5 stud hubs will fit and as matt says they will redrill easy :D
Postby camper extraudinair » Tue Sep 25, 2012 7:02 am
Have decided to go Jaguar as they are probably in
more plentyful supply possible moreso than mk1 & 2
transits.
I started by buying a pair of xjs front hubs complete
with great big four pot calipers the were delivered
at about four in the afternoon but i was out at the
time so the wife took them in.
The friend of mine who dropped them off had not
been paid so would pop in tommorrow.
I started by dismantling the jag hubs as all i wanted
was the hub disc & calipers.
Next i dismantled the transit hubs including the stone
guard & proceeded to slide the jag hub onto the Transit
s/a but the disc stopped it from going on.
I removed the disc from jag hub & on it went of course
the bearings were much larger so i fitted the transit
inner bearings after removing the jag grease seal &
bearings,unbelievable the hub spun as if it was made
for it.
Next i offered the very large jag caliper up to the T hub
again unbelievable the holes lighned up.
When my friend arrived the next day to collect his money
he could not believe it either.
He said he had lost sleep over how was i going to fit the
top & bottom ball joints to a beam axle.
The next job was to find a disc to fit the hub & also the
caliper.
I decided to go to a car dismantlers whilst visiting my
daughter on the outskirts of southampton.
There is one just up the road from them so in i went
why i don't know but something in my head said volvo
but as i walked past alfa's rovers i kept measureing
the diameter & offset of all the cars with five stud hubs.
The nearest was a volvo v70 it had a five stud hub 25 m m
inch offset & 280 m m dia disc.
On Monday morning i ordered a new pair of discs for said volvo.
camper extraudinair
Postby Luke » Tue Sep 25, 2012 10:11 pm
i'd like to see some pics 8) interesting stuff :D
Postby camper extraudinair » Wed Sep 26, 2012 1:26 pm
Just a few pictures for now...more to come soon
camper extraudinair
Postby camper extraudinair » Wed Sep 26, 2012 3:38 pm
camper extraudinair
Postby camper extraudinair » Wed Sep 26, 2012 3:51 pm
camper extraudinair
Postby camper extraudinair » Wed Sep 26, 2012 5:20 pm
Hi Transit lovers
So far this convertion has cost me £60 pounds for the front
hubs £67 pounds 10pence for the discs £24pounds odd for
the brake pads plus the volvo discs need the hole enlarged
to fit the hub centre of the jag.The cost of which i don't
know yet.
Next comes the new revolution wheels at £300 pounds & 50
pence including delivery.
Not last or least two new Bridgestone tyres 225 70 15 at
£218 pounds & then the front brake hoses & pipes.
Any problems will let you all know after road testing.
camper extraudinair
