di fuel pump
di fuel pump
Postby snakemaster » Tue Jul 12, 2005 9:27 pm
Hi could any body tell me how to turn up the fuel on a 1990 cav diesel injection pump
snakemaster
Postby MrMPuk » Tue Jul 12, 2005 9:33 pm
How do you mean turn up the fuel?
Postby snakemaster » Tue Jul 12, 2005 9:41 pm
Turn up the pump add more fuel to the engine throw the injectors ie more
power as it is runing lean, pumps a little goosed and needs a kick up the ass
snakemaster
Postby transitgeoff » Tue Jul 12, 2005 9:50 pm
classified :lol: :lol:
transitgeoff
Postby nr.6 » Sun Jul 31, 2005 11:38 pm
I have restored several Leyland O.600/680 engines, both horizontal and vertical ones. Changed CAV DPA rotary pumps for CAV or Bosch in line ones. Results: more even running, about 15 more horses. But, my experiments learned me not to fiddle with manufacturers' pump adjustments as more fuel pumped into injectors will only cause more fuel consumption and perhaps smoke, not significantly more torque. I even blew up an engine after fiddling with pump adjustments resulting the engine could make too much revs but no more power. My advice would be: carefully have the system checked and bring it back to its original specs. If you want more power, install another, more powerful engine.
Be seeing you !
nr.6
