tmbleweed wrote:Hi everybody
I am a new owner of a 2010 Ford Transit. I have spent over a week trying to figure out why the right turn signals (front and rear) wont work on my van. I have already tried to locate fuse/relay for the signals. I understand the van has front headlamp and taillight fuses for each unit not separate fuse/relay for signals. I have also disassembled the switch and shorted the pins. Left turn and high beam works by shorting the pins but not the right turn signal. So I figured out signal switch as the culprit. I am almost out of ideas. I would appreciate if one of you can guide me in the right direction. thanks.
ayance wrote:tmbleweed wrote:Hi everybody
hello friend, did you solve the problem? can you give information
