Mk 6 Bonnet lock
Mk 6 Bonnet lock
Postby ST-ROB » Mon Jul 15, 2013 9:35 pm
The key won't open my bonnet lock and seems to be jammed somehow. Any suggestions how to release it without the key ?
ST-ROB
Re: Mk 6 Bonnet lock
Postby SLIPPY » Mon Jul 15, 2013 9:57 pm
A new cheap key cut should do the trick, mines just cost £7 and it solved my same issue . Twice it's happened with 2 vans and twice a new key cut solved it.
SLIPPY
Sportvan Owner!
Sportvan Owner!
Postby Altransit » Mon Jul 15, 2013 10:01 pm
Ditto with the new key ^^^^^^^^^^^^^^^ doesn't need to be coded so is cheap to buy :D
Postby ST-ROB » Mon Jul 15, 2013 10:37 pm
Cheers for that. I will get a new key cut tomorrow.
ST-ROB
Postby ST-ROB » Wed Jul 17, 2013 11:14 pm
Not been able to get key cut as the key I have is too worn to read apparently. As I still can't open the bonnet has anyone any other suggestions. cheers.
ST-ROB
Postby Punto443 » Wed Jul 17, 2013 11:20 pm
Try flooding the lock with wd40 and pushing down hard on the bonnet while turning the key :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby SLIPPY » Thu Jul 18, 2013 3:21 am
I went thru all that and it never worked (WD40 etc )
Ford couldn't read my key either as it was so worn however as it can only be a couple of variations they got it on 2nd attempt/guess
Take your van to the garage , get them to cut a key and if it don't work ask them to tweak it slightly again while your there. If they can't do it .... Try another garage who can
A bit over my heed as I usually just break into things so no need for keys, but for only £7 it will still be your cheapest , quickest and safest method
SLIPPY
Sportvan Owner!
Sportvan Owner!
Postby Brains_transit » Thu Jul 18, 2013 11:59 am
I took a well worn key to timpsons and the guy could tell what the letters and numbers were to cut it and it worked perfect
Brains_transit
Postby BBB » Thu Jul 18, 2013 8:57 pm
Punto443 wrote:Try flooding the lock with wd40 and pushing down hard on the bonnet while turning the key :D
Although a newbie i had the same problem with a worn key and i took the rubber shroud off from around the bonnet lock and the key went in that little bit better and opened the bonnet. I did however get a key made pronto.
BBB
Postby ST-ROB » Sat Jul 20, 2013 8:42 pm
Well if all else fails, break out the drill. Have to open it with a screwdriver but at least I was able to check my oil and water. No doubt a new lock will be next on the shopping list.
ST-ROB
Postby transit mark » Sun Jul 21, 2013 2:17 am
ST-ROB wrote:Well if all else fails, break out the drill. Have to open it with a screwdriver but at least I was able to check my oil and water. No doubt a new lock will be next on the shopping list.
Ive drilled mine too, just use a flat screw driver. Fine for the mot. I might but a new lock but at least i can get in the bonnet now.
2001 MK6 90PS MWB RWD
transit mark
Postby everleigh » Sun Jul 21, 2013 8:52 pm
OK, how much do you drill out? I've removed basically the whole barrel back about 15mm using a 10mm bit. I can move the remaining mechanism easily to the left and right but it still does not engage the locking mechanism i.e. when I turn it left I can't lift the bonnet at all to then turn it right and release the bonnet. I've pressed the bonnet down etc. Do I continue to drill right through - and what then would I turn? Thanks!
everleigh
Postby Road2manchester » Thu Jul 28, 2016 8:55 am
I read a lot about how to do the OPENINg but , but what happens when all this fails.
After 3 hours of fiddling with the keys, I drilled the lock first with a 4mm bit, then a 10mm bit, but once in by 12-15mm it came to a stop and with a flat screwdrive the lock still does nothing,
Left turn to about 11 o'clock nothing.... to the right is goes to about 2 o'clock, with some resistence.... but nothing. The bonnet will not go up or down.
There are no bolts showing apart from one on a rod that seems to go to the back of the lock from below.
QUESTION IS: What next ??? How far in do I need to go in with the drill and best size ?
Cheers
Pete Road2
Road2manchester
Postby knobby1 » Fri Jul 29, 2016 3:54 am
Road2manchester wrote:I read a lot about how to do the OPENINg but , but what happens when all this fails.
How far does a normal key go in....just measured my key and it is over 30mm till it hits the black bit..!
You may have to go in a lot further..!
Wish my missus would say that...wish I had the equipment to do that..! :roll: :wink: :oops:
Postby Road2manchester » Fri Jul 29, 2016 1:29 pm
I spent 2-3 hours with WD40.... jiggles and hammer to see if mine would budge. Then sorted it this way.
Removed the grill as previously mentioned here somewhere.
Drilled the centre of the lock with a 5 mm bit, then again with a 10 mm bit. (Brutal I know).....
Having gone in about 25mm, you can eventually get to the + section of the lock and hey presto, a flat screwdriver worked. Left then right,
Visit to ebay, and for £14 I get a new lock (just the bit the key goes into) and two keys.) .
The bolts holding the housing to the bodywork are 10mm
The ones on the lock itself are 6mm
I made a video but having trouble downloading it,,,,
Road2manchester
