Van: 2005 VH SWB 2.4 TDi Duratorq with ASM Gearbox
Issue: Van starts and drives beautifully . Gears change up and down nicely. Accept... not long ago my ASM light was coming on intermittently then going away again. No obvious issues so ignored
Recently, whilst cruising along slowing down for an intersection @ about 50-60kph in 4th gear (auto or manual mode) - if my REVs drop low but the van is still rolling quickly, 4th gear slips and there is an awful crunching sound as it is trying to find a gear then usually ends up in 5th(sometimes 3rd). It is only under these very specific circumstances it will happen. Sometimes I can sit in 4th driving down a gentle slope using the compression of 4th gear to slow the van down on purpose for testing and it wont do it. If I am driving in manual mode I can manually select to drop down from 4th to 3rd before the revs get low and it goes nicely. Its really random but ALWAYS whilst in 4th gear. Other times just cruising along in 4th gear, as soon as I back pedal just a tad, BOOM! it slips and does the grinding and tries to slip into gear again. Eventually finds one though. I don't have to stop/start/put it into neutral like some others on the forums do... All other gears are absolutely fine.
DTC Codes: Using a Bluetooth ELM327 and Forscan software, I have managed to do some troubleshooting myself. Codes I have received are listed below. The ones in bold are persistent:
- Code: P0571 - Speed Control Brake switch circuit failure (Which I have now Fixed)
- Code: P2711 - Unexpected mechanical gear disengagement (This one is the regular one which occurs with the issue explained above)
- Code: B1319 - Driver door switch malfunction (which I have now fixed - or has gone away)
- Code: U1900 - %%h(CAN)(186E4) communication bus fault (This one comes up a bit - thought it might be a false negative from my cheap scan tool?)
- Code: P0717 - Turbine speed sensor circuit no signal (Haven't Seen this one for a while)
- Code: P1643 - Fuel pump monitor circuit low input (This one is coming up a lot now however tonight I managed to clear it by cleaning a connector which I thought was on the fuel pump but not sure now... will test further tomoz..)
What I have been doing is checking all the fluids (which are fine), sensor connections on transmission, fuses, switches, relays (which all seemed fine) and the more I play around with the electronics, the better the van is getting! 4th gear crunching/slipping is still occurring but much more gently now since re-establishing some connections- almost unnoticeable sometimes accept for the flashing light on the dash.
My gut feeling tells me there is an electrical issue but where??? Can this Fuel Pump Monitor Circuit be causing an issue? I have tonnes of specific PID readings too if that helps anyone? Any help would be greatly appreciated! I will be sure to post the solution weather I find it here or elsewhere also.
Thanks guys
