turbo ?
turbo ?
Postby snakemaster » Fri Aug 05, 2005 3:33 pm
What do i have to do to non turbo di engine to fit a turbo and make it run
wright
snakemaster
Postby MrMPuk » Fri Aug 05, 2005 4:30 pm
We have had this same question asked a few times on here now and I'm sure that most of the other members will agree that we came to the conclusion that it can't be done, you're better off just fitting the turbo engine!
Postby Luke » Fri Aug 05, 2005 5:35 pm
true what mrmpuk says!! but it can be done!
im no expert but i think you need a specially designed turbo kit,not off a turboDi
:D
Postby transitgeoff » Fri Aug 05, 2005 6:42 pm
ive already done it on a 1997 Transit transporter i built with 17foot body :shock: i had standard di engine, bolted on turbo di turbo and inlet manifold, 76 ps "banana"style fuel pump that i turned the fuel up on, the one thing you must do is use turbo injectors, once i did this the truck went to work and is still used daily and it FLYS it wipes the floor with those nasty lucas epic fuel pumps, and its faster :D so i built that nearly three years ago and still going strong so the answer is yes it can and has been done :wink:
transitgeoff
Postby madmark » Fri Aug 05, 2005 7:08 pm
:shock: wow geoff you never said you had done this conversion! mind you getting hold of the turbo and manifold would be hard wouldnt it???? :?
Postby transitgeoff » Fri Aug 05, 2005 7:14 pm
well the step ladder can get a bit wobbly when im on it pulling the turbo off the top shelf :lol:
transitgeoff
Postby MrMPuk » Fri Aug 05, 2005 7:20 pm
They only thing I get off the top shelf is porn, and I don't need a ladder anymore! :lol:
Postby Luke » Fri Aug 05, 2005 7:25 pm
madmark wrote::shock: wow geoff you never said you had done this conversion! mind you getting hold of the turbo and manifold would be hard wouldnt it???? :?
what for mark your never gonna but a Di in yr mk1 are you? :?
Postby snakemaster » Fri Aug 05, 2005 7:51 pm
Hi Geoff thanks for the info, where did you get the oil feed from? i have a
lucas pump and the engine is a 1990, what do you mean by a banana"style fuel pump that i turned the fuel up on, i was hoping to put a
petrol injector on the inlet manafold and a e pump and a fuel tank for this
and run a small spool valve to regalate the derv fuel
snakemaster
Postby madmark » Sat Aug 06, 2005 9:25 am
no luke no di mate i would need a set of ear muffs in a mk1! :lol: :lol:
