turbo problem
turbo problem
Postby tommo » Thu Aug 11, 2005 10:27 am
turbo transit problem 1994 help it runs fine till i drtop revs bellow 1000 then it runs with no power but if i turn it off and re start it runs ok till i drop bellow the 1000 rpm area????? please can any body give any suggestions :cry: :? :(
tommo
Postby jay » Thu Aug 11, 2005 7:21 pm
what do you mean it runs with no power??do you mean it has no power when you go to acelarat if so check the throttle switch and all connections
mk1 connect tourneo
jay
turbo problem
Postby tommo » Fri Aug 12, 2005 10:01 am
after droping below 1000rpm van wont go more than 45mph till i stop engine and restart then power returns :?:
tommo
Postby ovlov » Fri Aug 12, 2005 8:37 pm
:shock: We had a L reg pick up used to run out of power esecialy on hills,
But if you stoped it and restarted it it would go okay for a while wasnt a turbo though. We had to get the pump overhauled cost £600 + vat nearly fell off my perch when got bill, I was told they break up inside or something like that. :lol:
I want to live forever so far so good
ovlov
Postby FredTransit » Fri Aug 12, 2005 9:30 pm
ovlov wrote::shock: We had a L reg pick up used to run out of power esecialy on hills,
Not suprised you fell off your perch ovlov, I can get a whole new pump for £600!!! :shock:
FredTransit
Mk2 Trannyist
Postby ovlov » Fri Aug 12, 2005 9:52 pm
:shock: Yea know what you mean Fred but van packed up halfway through a job needed it back urgent so just rushed into it without thinking realy you no how it is, you learn by your mistakes :cry: :cry: :cry:
ovlov
Postby FredTransit » Fri Aug 12, 2005 9:56 pm
ovlov wrote::shock: Yea know what you mean Fred but van packed up halfway through a job needed it back urgent so just rushed into it without thinking realy you no how it is, you learn by your mistakes :cry: :cry: :cry:
Indeed, indeed, Ya live and learn!
FredTransit
Mk2 Trannyist
Postby bortaf » Sat Aug 13, 2005 1:48 am
If it was a petrol i'd say TPS,
switching off the ignition resets the ECU (at least it does on simple ECU systems like CFi fiestas and sierras.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby tommo » Sat Aug 13, 2005 12:08 pm
THANKS FOR SUGGESTION BUT FITTED NEW PUMP COST NEARLY 800 SUGESTED TPS IF IT WAS PETROL :?: WHAT IS TPS EXCUSE MY IGNORANCE WILL A DIESEL HAVE SAME :?: :idea:
tommo
Re: turbo problem
Postby jonnyshag » Sat Aug 13, 2005 10:02 pm
Hi, i had this problem with my tranny turbo , check the oil level and water level and check for leaks , i had a slight oil leak and it udes to get worst and worst everyday , ford dealers are usless they couldnt find any probelms they put computer to ecu, i checked the oil 1 morning found it where below the min line so i put so oil in and it ran fine , but dont fil pass max line course that will course it to happen ,
Everything runs though the ECU and if there a problem which can cause damage it sends a signal which then the van goes into a limp mode , basicley you cant over rev the engine , limp mode give you time to stop and gets you to saftey
hope this helps :)
jonnyshag
