by trxdavid » Thu Aug 18, 2005 9:54 pm
Don't know if this will help or not, but I have a '95 2.5d with a Bosch pump and it was never a rocketship but about 6 months ago it got steadily worse over a period of about 2 weeks, so bad that lots of hills were second or even first gear. A local deisel specialist pointed me in the right direction-it turns out there are a couple of springs in the pump which bear onto a face cam and control the main plunger. The springs control the position of the plunger in relation to the main body and make sure that the correct amount of fuel is delivered to the right place at the right time. If one (or in my case both!) springs break the efficiency of the pump, and the engine, is drastically affected. That was the explanation I was given,
The springs were replaced and hills that used to make it struggle in second gear can now be accelerated up in third. "Transformation" would be a real understatement!
Good luck, hope this helps.
