ECU Coolant light problem
Postby Brucew » Sat May 31, 2014 10:47 am
Hi, I'm New to this board and was wondering if anyone might be able to help me with a problem with my
Ford Transit 96 turbo Diesel Vin # SFALXXBDVLTL10150
I had a very small leek from a small crack in the thermostat housing I purchased a second hand one from the other side of the country,
It had a crack too,Only when hot.
it went into limp mode occasionally so i did the old “stall in 5th gear and turning off the ignition at the same time trick”( Reset the Computer)
And i was on my way again .
The van never over heated
I finaly found a new Thermostat housing in the UK, it cost $250.00 Aussie to get to me .
I fitted the new Thermostat housing with a new Thermostat ford Australia recommended . Refilled the the Coolent and bled the system .No Leaks
It dose run a little hotter now ,Themo Gage used to sit just under ½ now it sits on ½ .
Now i have the ECU warning light coming on intermittently just under the temp gage on my dash .
I think it is the Coolant ECU Sensor
Tried to post a pic but carnt.
And it is going into limp mode after every morning start , but then fine all day. with the ECU Sensor light flashing.
I have all so tried This
ECU reset...the official method
by lightning » Fri Aug 07, 2009 5:31 pm
Well, here's the official line.
It's called a "Power Latch".
Warm up the engine to operating temperature.
Turn off the ignition, then turn it on again to position 2 (running position) DO NOT start the engine.
Open bonnet and REMOVE BATTERY POSITIVE LEAD with the IGNITION STILL ON.
Then you have to touch or short the positive wire (that you just took off the battery) to earth (still with the ignition on)
Turn off the ignition.
Reconnect the lead to the battery.
Start the engine and DO NOT TOUCH THE THROTTLE, let the engine warm up until the cooling fans cut in, or at least until the temperature gauge shows normal operating temperature. (Should not take too long as the engine was already at operating temperature)
Then drive normally, accelerating steadily up to 4,000rpm through the gears if possible.
This resets the ECU and it will then re-learn fuelling etc.
Does not take long as no need to leave battery disconnected for more than a few seconds.
Radio will need code entering and clock will need resetting.
Could a slightly hotter Thermostat Cause this Problem and dose anyone know what the correct thermostat heat range should be?
Cheers
Bruce
Brucew
Re: ECU Coolant light problem
Postby ake » Sat May 31, 2014 7:26 pm
Is the light that's flashing a picture of an engine? Or something else
Postby Brucew » Sun Jun 01, 2014 9:36 am
ake wrote:Is the light that's flashing a picture of an engine? Or something else
No it's not the engine light , Its yellow and has a water container looking thing with 3 wavey lines running horizontally in it.
I'm still trying to figger out how to post a picture in my message.
Brucew
Postby ake » Sun Jun 01, 2014 12:50 pm
That's the water in fuel filter warning light. It's completely unrelated to ecu or engine running and won't put engine into limp mode
It's probably just faulty, but I would try a new fuel filter, and if the timing belt has been done in a while it should be changed, worn belts can cause limp mode
Postby Brucew » Tue Jun 03, 2014 8:30 am
Cheers ake, i have had 2 mechanics tell me it was a ECU sensor ,
Thanks again mate you have saved me a lot of time and money.
Brucew
Postby Brucew » Tue Jun 03, 2014 8:41 am
One other Question You might know ,
Is there any one on the east coast of Australia who rebuilds Transit Fuel pumps as i have a leaky one?
Brucew
Postby Altransit » Tue Jun 03, 2014 9:21 am
It may just need a new seal or O ring fitted ...............................From your first post, it sounds like the ESOS needs replacing as well :|
Read down :arrow: viewtopic.php?f=27&t=69451&p=590932
Postby Brucew » Wed Jun 04, 2014 4:11 pm
Thanks for the advise Altransit,
Looks like i just need a Square Hall Sensor Seal, ( is that what it is called) ?
I have seen alot of AndyG's posts slowly putting 2 and 2 together.
Ive been searching hi and low To get a Square Gasket here in Australia.
Got some feelers out just Waiting in limbo.
You are Spot on with a faulty ESOS .
Any advise on how to replace the ESOS or links on this problem would be appreciated.
Ps All of most of the posts with pictures, the pictures have been removed.
PPs I might have to get the Title of this thread renamed.
Cheers
B
Brucew
Postby Altransit » Wed Jun 04, 2014 9:35 pm
I'm sure there is a thread somewhere about replacing the ESOS, but I can't find it at the moment. I'm not sure if it was one of Andy's or not :oops:
Dieselhead123 on here can always help with Lucas pump parts, send him a PM if you're struggling to find stuff where you are :D
The missing pictures, sadly, are a result of the original poster moving or deleting his pictures from the hosting account, and there's nothing we can do about it. It would be a mammoth task to copy the more important pics to a forum account, and change the links, although it has crossed my mind :roll:
Postby Brucew » Sun Nov 11, 2018 6:59 am
Abit of a 4 year lag but Thanks for your Help Altransit.
Brucew
