bambi mk 1 wrote:I thought you had it running by your other thread Which cams did you use How much did the machine shop charge to bore the injector ports
Mad Husky wrote:I was going to say won't the cams in the tdci be different due to the position sensor needing a pick up point, which I would have guessed would have been missing on the tddi cams but after reading previous posts obviously not.
