loot34 wrote:Can anyone confirm that the fuel rail pressure at tickover is 20.00 kpa?
knobby1 wrote:loot34 wrote:Can anyone confirm that the fuel rail pressure at tickover is 20.00 kpa?
I think it says 20.87 Mpa Loot...
But the fuel rail temp seems a tad low @ 3c..! One would assume that if it's been running for a minute or so the fuel temp would be higher than 3c..especially since the ambient air temp reads 9c...!? Maybe the pressure/temp sensor is on the way out..?
bambi mk 1 wrote:Had this problem a while back.Van came in not running prv goosed.Changed prv and scv cleared codes van starts warms up to do learns and stop engine.Would not start.Comes back next day and starts first turn warms up and no start.No codes but changed crank sensor and hey presto away she goes
