loot34 wrote:I updated my speedo and it has the light on which comes on with the ignition, would this procedure activate mine or do i need to configure it in my software too? Not started on any big hills since tho, do they have to be steep or what?
robbie.cee wrote:Was that the proceedure to reset service light or was that a different trick with the pedals ??
chooseatransit wrote:bigbad mothertrucker wrote:
turn off ignition , hold all pedals down ,turn on ignition hold untill the light comes on and flashes. keep holding till light goes out . sorted. assist also goes off when you accelerate. have you done this? i thought hill assist started on reg 08 reg transits onwards
Digging up an old thread here lootboy? I thought you'd got it working? Or is it time to change another ABS pump? I thought you had a custom wheel on asbo? As was going to as about comparability and how many wires it had for the phone buttons.... ? But that's for a different threadloot wrote:My present van doesn't seem to work
I don't have cruise control working because the buttons aren't present so there's adtc for cruise switch, it is activated though.
Hill launch is turned on via ids and says it is on, no hill launch lamp comes on at all though its green the same as cruise and gear change lamps which do come on then off at ignition.
Airthies wrote:Digging up an old thread here lootboy? I thought you'd got it working? Or is it time to change another ABS pump? I thought you had a custom wheel on asbo? As was going to as about comparability and how many wires it had for the phone buttons.... ? But that's for a different threadloot wrote:My present van doesn't seem to work
Sent from my Armor_6E using Tapatalk
Users browsing this forum: BimmerGuy, Google [Bot]
