GerryVega wrote:Hi,
I've got pretty much exactly the same problem as the previous poster: leaking heater matrix, in France, seeking quick fix. I've got the pipe and clamps, now trying to tell myself it's Ok to cut the hoses. Any recommendations where? Should I expect much coolant to come gushing out? Ideally if the original poster had a photos of the quick fix bypass that would be fantastic but no worries if not.
Cheers for any help
Disconnect the hoses as I mentioned earlier and then cut the metal pipes of the matrix not the rubber hoses and then insert the cut pipes back into the hoses and bridge the gap with your new hose and clips
