engine cutting out
engine cutting out
Postby michael » Wed Sep 07, 2005 1:02 am
on my 93 2.5 diesel.First happened when i picked the van up a couple of weeks ago.lost power going down a duel carrageway and the engine cut out as i came to a stop.looked under the bonnet and one of the battery terminals was loose.Fired up straight away and has been good as gold for two weeks but its just happened again tonight.Haven't had a chance to look under the bonnet yet but i'm fairly certain its not a battery terminal again cos i tightened them both up before.Any ideas what else it could be?
Cheers in advance!
michael
Postby Luke » Wed Sep 07, 2005 8:13 am
Could be the wire to the diesel shut off solenoid -that would cut it out!!! :D
still reckon it will be the battery leads though!! - with you having the problem before - mabe the clamp bolt threads are damaged and working loose!! :?
Postby michael » Wed Sep 07, 2005 10:42 am
Went out this morning and checked the battery terminals and they are fine. :?
michael
Postby jay » Wed Sep 07, 2005 10:49 am
what happens when engine is turning over(if it is??)d oyou geet smoke out of exhaust and is the stop solinoied working and connected(what engine is fitted)
mk1 connect tourneo
jay
Postby michael » Wed Sep 07, 2005 10:53 am
jay wrote:what happens when engine is turning over(if it is??)d oyou geet smoke out of exhaust and is the stop solinoied working and connected(what engine is fitted)
Hi mate.The engine turns over fine.No smoke as far as i'm aware.
Stop solenoid? Whats that?
Don't know much about the engine other than its a 2.5 diesel.
michael
Postby Luke » Wed Sep 07, 2005 11:09 am
If its turning over then it wont be the battery teminals!
michael wrote:Stop solenoid? Whats that?
its on the diesel pump should have a wire going to it! and its on the lhs looking form the front! may be just the wire has fallen off!!
:D
Postby michael » Wed Sep 07, 2005 11:29 am
ah ha!Wire was a bit loose.hopefully will be ok now.Gave it a bit of a clean up aswell so hopefully everything will be ok now.Was a bit too dark to notice last night.Hadn't even looked at a transit engine until a couple of weeks ago but sould learn fast with everyones help on here.Cheers!!
michael
