MK3 6 stud rear axle change stud bolts
Re: MK3 6 stud rear axle change stud bolts
Postby knobby1 » Thu Sep 06, 2018 11:43 pm
gwynfe wrote:Just snapped the stud on my recently purchased mk3 100l camper.
I feel rather stupid as I was unaware it was a left hand thread. Anyway can anyone help with some information on the stud part code and where I can purchase it and also the left hand thread wheel nut
Many thanks
Sent from my Lenovo TB2-X30F using Tapatalk
Does this help..?? #3 here:
http://www.catcar.info/ford/?lang=en&l= ... NTc2KzA%3D
And #9 here:
http://www.catcar.info/ford/?lang=en&l= ... OTIwKzA%3D
There's a listing for left and right side....left side will be left hand thread..!!
Postby Mòchen » Mon Sep 10, 2018 3:28 pm
here you are, i found this. The code is Ford 1571934 or 1571933 for normal thread.https://www.ebay.co.uk/itm/Genuine-Ford ... 2721445131 :D
Mòchen
Postby gwynfe » Tue Sep 11, 2018 11:14 am
Thank you for your help.
Unfortunately still having big problems finding the correct stud.
The transit camper ( conversion) is a 1989 100l
Wheels are 14" six stud ( offside right hand thread, nearside left hand thread)
Rear axle is single wheel German type with 12 bolt diff cover
Wheel studs are M16 x 1,5 and total length 64mm
Thanks for your help
gwynfe
Postby Mòchen » Tue Sep 11, 2018 2:25 pm
i Also have a 100L model dated 1990. Front wheel has same bolts as yours.
For rear axle give us a picture, so i can chekc with mine.
Mòchen
Postby gwynfe » Tue Sep 11, 2018 2:57 pm
Yes having great difficulty finding the correct stud here in the UK for some reason.
As you can see I've already removed two studsImageImageImage
gwynfe
Postby Mòchen » Tue Sep 11, 2018 3:22 pm
looks the same of front wheel's studs. Did you compared them?
Mòchen
Postby gwynfe » Tue Sep 11, 2018 3:25 pm
Mòchen wrote:looks the same of front wheel's studs. Did you compared them?
Yes same as front wheel studs but impossible to find anywhere in the UK.
Finally found some on motomobil.com
gwynfe
Postby axxez » Mon Sep 17, 2018 10:26 pm
Hm.. I have a picture of the package of the ones I used in my van and the print on it is as followed:
1 427 964
STUD
STIFTSCHRAUBE
ESPARRAGO
GOUJON
VITE PRIGION.
2402E 1119 D
HPMS.NO.
MFL001
--> So pretty sure the number is 1427964. Those studs where for my rear axle, left-thread (L)
axxez
Postby gwynfe » Mon Sep 17, 2018 10:44 pm
Thanks for all the info guys,
Managed to get the studs and nuts from motomobil Germany,
seems like the only place on the planet that has them.
I bought two for spare just in case. Quite expensive about £55 for three studs and nuts ( this includes postage)
But a great company to deal with, delivery was very fast, I can highly recommend this company.
One question
I could not undo the fill / level plug on the differential so jacked up one side of the van quite high and removed the half shaft and poured new diff oil straight in, roughly the same amount that came out when changing the studs. Will this be OK or is there something I may have missed?
gwynfe
Postby axxez » Wed Sep 19, 2018 12:39 pm
That should be it, just take care to seal the half shaft proper: seal removal, oil removal, new seal-paste (I think I put it on the shaft itself as it is easier). Also put new grease on the outer wheel-bearing and check the inner one. By the way, does anyone have the partnumber for those half shaft nuts? Mine are a bit woren out...
axxez
Postby gwynfe » Wed Sep 19, 2018 3:14 pm
axxez wrote:That should be it, just take care to seal the half shaft proper: seal removal, oil removal, new seal-paste (I think I put it on the shaft itself as it is easier). Also put new grease on the outer wheel-bearing and check the inner one. By the way, does anyone have the partnumber for those half shaft nuts? Mine are a bit woren out...
Yes I put gasket sealant on the face of the shaft where it buts up to the drum.
I also packed the bearings with grease, but to be honest I later wondered if this was the correct way.
Surely the axle oil has free movement to the bearings would this not lubricate them and the grease might act as a barrier?
Maybe I'm way off the mark but just a thought, what do you think?
gwynfe
Postby axxez » Thu Sep 20, 2018 7:34 am
Haha :D Well, this bearing gave me some sleepless nights as well. In fact, the outer bearing deffinetelly runs in the axle oil, the inner one does have a rubber sealing to prevent running in the axle oil. Still, the Hayne's repair manual tells to grease both of them, which confused me a while ago. But a mechanic explained to me that this grease is better for the bearing than the axle oil, although the axle oil is quiet viscous. So the outer bearing runs on grease for a long time, until it is washed out / serviced again. The inner one runs on grease for a very long time, until the rubber sealing breaks and than can still run for quiet a while on axle oil as a backup. I had a broken sealing in an inner bearing once and didn't notice anything, until I opened the axle for another reason.
This little bit of grease retourning to the axle oil by the way is also not a problem. You could maybe run the complete axle in grease, would be more load for the rest of the drivetrain but it should work.
axxez
Postby Timelourd » Sat Jun 22, 2019 2:22 pm
Looks like this problem was solved, but I'm looking for help locating the fill plug for the rear diff on the mk3 - can't find it anywhere and the manual just tells you it exists!
1996 2.5di MK5 Banana Engine
Timelourd
Postby Timelourd » Sat Jun 22, 2019 7:05 pm
Nevermind. Found it on the bottom of the housing facing towards the front of the van.
Timelourd
Postby Mòchen » Wed Jun 24, 2020 12:27 pm
Hi guys!
Coming back on this old post. I recently changed rear brake pads, and i want to share as i worked on bearing fixing nuts.
I used, as described on Haynes manual, a dial gauge, so:
1) Rear brake pads change
2) Re-mounting rear drum with bearings, on shaft, and check rotation. I give 5-6 run to the drum to be sure play was dealt.
3) Put on shaf the firs nut, turn it, and accost to external bearing.
4) At this point, fix on drum the dial gauge and set the feeler on external shaft face, and test the play.
5) turn the nut (by hand) till you reach the play as described in manual (from 0.05 mm to 0.2) i set it at 0.05mm.
5.5) Turn drum 6-7 times and repeat this operation till play keep costant.
6) after that put on tab washer and the second nut.
7) tight second nut at 85 nxm.
8) remeber to fol tab washer tabs on nuts.
Drums final runs easly and with out strange play.
Mòchen
