New transit owner wrote:2.4 100 Bhp 350 yeah I have had a look at the fluid looks a tad low
But good have been low before if u get me when I fly over to work
I will have a quick look and add more if I can cheers for advice andz
Just anoying shelling out 600 notes last year on clutch duel mass normal mechanic
That did it is on holiday typical thanks again
New transit owner wrote:Yeah will do had a good luck before cant see anything leaking
Part from the rear oil seal which has covered most things lol going to attack
That's if gear box has to come out but will try a master cylinder first I even
Got my mate to move the stick while I was under it a the parts moved freely
Of what I good see nothing seemed stuck
New transit owner wrote:Hi all thanks in advance for advice info I have a mk7 transit drove
Spot till I turned engine off now won't go into gear when engine running
Will go into gear with engine off and will drive till I have to change gears
Any advice would be great checked for leaks in fluid but haven't a clue
On what to do local garage say clutch but a new one got fitted s year ago so
Thanks again
v8dave wrote:New transit owner wrote:2.4 100 Bhp 350 yeah I have had a look at the fluid looks a tad low
Fluid level will stay up in the filler neck even when the reservoir is empty, as there is a weir between the neck and the reservoir.
