by mjjordan » Wed Mar 08, 2017 6:21 pm
It is possible ! I cut the top thumbgrip off the standard knob so it wouldnt foul the new door covering when turning. Then I drilled it and put through a thin bar i found with a flat end with a hole in it, screwed in to the half knob tight. Now I had a knob in the lock which didnt stick out , with a "lever" attached to it, all inside the door.. If i could think what said bar came from i would say, but the memory cells have gone blank. I then got a spare knob that you would have to internally open the transit rear doors if you had a minibus and engineered a mounting for it from perforated bar ( so i could change position if I had to) near the front of the door. measurements and positioning were dictated by another piece of scrap I found, which I think might be a cross stretcher for the rear of a flat pack wardrobe ( its about 3mm bar about 3' long, with flattened ends with a hole in them, and a similar arrangement in the middle). 1 end co-incides with the new "lever" on the now half knob in the lock so that a small bolt and nut with washers between and a locknut on the end allows it to move but not fall off, the other end fits on the pin at the rear of the minibus knob, and this, again for locking on whilst retaining turnability has one of those washers with an internal grip to the rod/pin fitted. There you have a remote knob at the front of the door - fob press for lock from inside - all doors lock(not deadlock- only 1 press, or you'll never get out without the key), new remote knob obligingly turns to rear confirming sliding door locked. Emergency exit, grab big new knob, turn forwards, door unlocked, grab latch handle as usual and slide door and gerrout! Should have taken pictures I know but forgot and door now nicely covered in with pretty carpet, sorry!
