Back wheel squeal driving me mad
Postby Birmingham » Fri Feb 23, 2018 12:05 pm
Morning lads. I have a mark 7, lovely runner, the only problem is this irritating squeal that comes when it’s warmed up. It sometimes takes up to an hour while driving, and I half do be thinking, bang on it’s gone, but the decker always returns. It’s on the back driver side. I thought it was a wheel bearing, but there is no grinding and it’s only when it seems to be warmed up. If I’m driving in a straight line it’s there, if I turn the wheel ever so slightly either way it goes, like sideways pressure is relieving the noise or the problem. I touched the back wheel and it was quite hot, which narrowed the problem down to the rear driver side. Checked pads and discs, they are fine. Just had it’s mot, nothing showed up at all. Could it be the brake calliper sticking? Or a dry bearing ? Zero grinding as I said, but I have to sort it, as it’s quite possibly the worst noise I’ve ever heard. Any advice would really help lads. Also it goes when I brake, when I release brake it’s instantly back..Thanks, chris
Birmingham
Re: Back wheel squeal driving me mad
Postby grogan197 » Fri Feb 23, 2018 1:26 pm
Check the runout with a dti on the brake disc. It's not unusual to get noises from the brake disc if the runout is over spec and it typically occurs once the brakes have warmed up. The runout should be no more than 0.1mm
2006 MK6 2.0 125 TDCI - Luton Camper Conversion
2007 MK7 2.2 110 TDCI SWB
Ford Diagnostics
Where to buy an ELM327 and how to use with ForScan
grogan197
Postby Birmingham » Fri Feb 23, 2018 2:42 pm
grogan197 wrote:Check the runout with a dti on the brake disc. It's not unusual to get noises from the brake disc if the runout is over spec and it typically occurs once the brakes have warmed up. The runout should be no more than 0.1mm
Sorry mate, what’s a runout and dti??? Thanks for reply
Birmingham
Postby grogan197 » Fri Feb 23, 2018 7:17 pm
DTI is a dial test indicator, you use it to measure the runout which is basically a measurement of if your brakes are running true. If they run with a slight wobble (excess runout) then the pads will rub against the disc and you will have uneven wear on the disc (not noticeable with the naked eye)
There's a guide on testing the runout here http://www.apecbraking.co.uk/getattachment/7c2582da-83bd-41be-8ecd-1ec73ea8ce8d/Understanding-Brake-Judder-and-Preventative-Steps.aspx
Ford Diagnostics
grogan197
Postby knobby1 » Fri Feb 23, 2018 10:37 pm
FWD or RWD..??
Also I wonder if the handbrake is holding on a bit?? Sticky cable or the caliper lever not going all the way off??
Postby Birmingham » Fri Feb 23, 2018 11:48 pm
knobby1 wrote:FWD or RWD..??
There was no travel hardly on the handbrake when I got it, hard to get one click. So I loosened the tensioner underneath the chassis. Now the handbrake light is on and only goes off if I apply pressure pushing down on handbrake when driving but as soon as I let the pressure off the light comes back on and the handbrake rises a little, like it won’t sit down properly. Do you think it needs slackening more ?
Birmingham
Sorry it’s fwd. Thanks
Birmingham
Postby andz327 » Sat Feb 24, 2018 9:54 pm
Caliper probably sticking on one of their slides or sticky H/cable lever on caliper
andz327
Postby Birmingham » Tue Feb 27, 2018 2:49 pm
andz327 wrote:Caliper probably sticking on one of their slides or sticky H/cable lever on caliper
Cheers mate, i'm thinking that too
Birmingham
Postby andz327 » Tue Feb 27, 2018 3:07 pm
Remember n/s/r caliper (anti clockwise) winds in opposite direction from o/s
andz327
Postby Birmingham » Thu Mar 01, 2018 1:32 pm
Thanks for reply. Would you just grease the slides and wd40 any springs involved like up at the handbrake .?
Birmingham
Postby bigjohnthomas » Thu Mar 01, 2018 2:20 pm
Take the caliper off and move it in and out and put some love juce on it
Bloody annoying squeeeeek that :x
bigjohnthomas
Postby Punto443 » Thu Mar 01, 2018 2:25 pm
Mine was doing this and it was the handbrake lever on the rear caliper sticking
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby andz327 » Thu Mar 01, 2018 6:49 pm
bigjohnthomas wrote:Take the caliper off and move it in and out and put some love juce on it
Lube juice it up............... yeeehaaaa
andz327
Postby Birmingham » Thu Mar 01, 2018 8:47 pm
Punto443 wrote:Mine was doing this and it was the handbrake lever on the rear caliper sticking
just a bit of lube ?
Birmingham
