knobby1 wrote:2000...?? Mk6..?? If so they are 2.4 not 2.5. The highest ps rating for the mk6 was 135ps....not sure if they can be reliably mapped though.
The only way you'll get 150-160ps is to "re-engine" it with something other than a ford transit engine.
bambi mk 1 wrote:Good God Knobby what are you drinking https://vantuner.co.uk/services/transit-power-tips/
Op scroll down the link and give Martyn a pm. 115 are not TDCI and can be tuned very successfully
Altransit wrote::idea: Has anyone considered that this could be a (rare) Mk5 2.5 TDi 115ps intercooled with an EPIC pump
PerreHedlund wrote:Just for the record... its 2496cc, type: 4ED*ZIFF.20-21:A Turbo : 530A 10 , Pump: 7187.002 2 and after asking the “motor vehicle inspection”, changing engine is not an option. I have to “tune it”! And I’ll go for 150 hp. // Perre
Jim Archer wrote:The usual marinised version of the 2.5 DI Turbo is rated at 130PS, and it will happily run at that for years.
wojciech wrote:Jim Archer wrote:The usual marinised version of the 2.5 DI Turbo is rated at 130PS, and it will happily run at that for years.
Yes, I know, but compare how many hours engine works on water to how many hours it works on road. Two different worlds...
Chuggy wrote:Is it just different injectors fitted to make the power increase from 100ps to 115ps, or are there other differences too?
or put another way, What would you need to do to the 100ps turbo engine to make it 115ps?
V184 wrote:Chuggy wrote:Is it just different injectors fitted to make the power increase from 100ps to 115ps, or are there other differences too?
If you mean the 2.5di the 115 (113) had a intercooler i think from an rs turbo, to be honest they didnt feel much different from the 100horse
wojciech wrote:V184 wrote:Chuggy wrote:Is it just different injectors fitted to make the power increase from 100ps to 115ps, or are there other differences too?
It's like that, because EPIC 115 HP was mounted usually to heavy or big models (Jumbo, Campers etc.).
Difference you will feel if you compare small Transit L1H1 with 100 and 115 HP. Especially about acceleration on lower gears - 100HP has torque 224 Nm, 115 HP has torque 256 Nm. It is about 15% more...
