Ken205 wrote:Sorry drake but have you changed the rocker yet or not
Crankcase pressure in any engine is mainly caused by 3 things, cracked piston, worn piston rings or no breathing and
You have compression in all 4 cylinders
You could check the turbo by disconnecting the return pipe and blanking the block and drop the pipe into a bucket to see if the oil is pressurised when the engine is running but I still don't think that's your problem . If the turbo was pressurising the crankcase and your breathing system wasn't blocked it would leave out the pressure
knobby1 wrote:I'm suspecting a cracked piston on the "low compression" cylinder.
Drake1793 wrote:knobby1 wrote:I'm suspecting a cracked piston on the "low compression" cylinder.
And with a cracked piston you do not see any kind of smoke on the exhaust?
I think the better way right now is to wait and change the parts ordered.
rebuilder86 wrote:ive just realised this reply was to me......
"No movement in / out only a little bit up/down but the rotor don't touch the side wall."
If thats talkign about the turbo, then its shot, it shouldnt move at all. You have the same problem as me and its the turbo,
