central locking locks but wont open again ????
Postby bigayal » Wed Aug 22, 2018 12:55 pm
hi there i have tried looking on here but i cant seem to find the answer i am looking for (due to being slightly obtuse i suspect :D ) if someone could help or point me in the right direction it would be greatly appreciated ,
right so the central locking will lock all the doors and sliding door but then wont open any of them again using the key there is no noise from any of the locks :( i dont have a fob at all but surely it should open using the key anyway right?????
thanks in advance for any replies
bigayal
Re: central locking locks but wont open again ????
Postby bigayal » Wed Aug 22, 2018 6:53 pm
bigayal wrote:hi there i have tried looking on here but i cant seem to find the answer i am looking for (due to being slightly obtuse i suspect :D ) if someone could help or point me in the right direction it would be greatly appreciated ,
sorry didnt read the forum rules first was in a hurry its a 2005 100 t260
bigayal
Postby omganyleft » Thu Aug 23, 2018 9:36 am
Just a thought.....when You turn the key to the right are You pushing it quite hard ? The lock mechanism is pretty stiff to actuate. Regards Stephen Australia
Sent from my Pixel 2 using Tapatalk
omganyleft
Postby amlav » Thu Aug 23, 2018 11:09 am
I would suspect the unlock remote button being faulty or dirty .
amlav
Postby bigayal » Fri Aug 24, 2018 5:49 am
hi thanks for your replies , yeah i am turning it as hard as possible without breaking it and i dont have the remote for it , i have ordered a new lock and fob will just have to wait and see if that works if not i havent got a clue :?
bigayal
Postby Altransit » Fri Aug 24, 2018 11:15 am
You can lock any Tibbe locked Ford with any Tibbe key, but only the correct key will unlock it, so it could be that you either have an incorrect key; or maybe the lock, or key, is worn (more likely the key)
Get another blank key cut, it doesn't need to have a chip, and if that unlocks the door, Bob's yer dad's bruv :D
Postby bigayal » Fri Aug 24, 2018 12:59 pm
Altransit wrote:You can lock any Tibbe locked Ford with any Tibbe key, but only the correct key will unlock it, so it could be that you either have an incorrect key; or maybe the lock, or key, is worn (more likely the key)
but the same key starts the van fine no problem and doesnt look worn too badly :s where cuts these keys would timpsons or something do these or is it a specialist job? thanks alan
bigayal
Postby Altransit » Fri Aug 24, 2018 2:27 pm
Well, it's worth a try.
My Mk6 had a key which started it, but wouldn't open the door or the bonnet, so I had an unchipped key cut just for that job.
Timpsons can cut one for you.
Postby bigayal » Fri Aug 24, 2018 4:53 pm
thankyou so much you guys are legends :D
bigayal
Postby bigayal » Sat Aug 25, 2018 6:51 pm
so the new key didnt work i have ordered a new lock and i messaged on anothr topic , they said it could be electrical which is not my forte :( thanks alan
bigayal
Postby Altransit » Sun Aug 26, 2018 12:43 am
bigayal wrote:so the new key didnt work i have ordered a new lock and i messaged on anothr topic , they said it could be electrical which is not my forte :( thanks alan
The door lock and key are purely mechanical and should work with no power, unless there's a mechanical problem with the lock or the key.
Postby bigayal » Sun Aug 26, 2018 9:37 am
fingers crossed a new barrel will sort it :) will let you know thanks alan
bigayal
Postby bigayal » Fri Aug 31, 2018 7:26 pm
hi there so i have a new problem because i cant turn the barrel to the unlock it properly i cant press the deadlock thing in to get the barrel out :s andd yes i have tried mc hammer on it lol please help thanks alan
bigayal
