IDS remapping
IDS remapping
Postby gregd72002 » Mon Sep 03, 2018 12:31 pm
Hi,
As per the title, I see two options:
    Trick the IDS to use a different PCM calibration file (same model but higher PS)
    Use IDS to run PCM as-built and change the Tag
Anybody has done/tried something similar?
Thanks,
gregd72002
Re: IDS remapping
Postby knobby1 » Tue Sep 04, 2018 3:28 am
gregd72002 wrote:Hi,
Anybody has done/tried something similar? Thanks,
I understand you have a Euro-5 2.2..??
This info below is for Euro-4 but I suspect yours may be similar.
I doubt it'll work as you want it to, the injectors are different flow rates depending on what ps you want to go to.... for example, the 100 & 115ps 2.4TDCi engines have lower rate injectors compared to the 140ps engine....and the turbo's are also different, normal wastegate type compared the electronic VNT turbo of the 140ps. So, essentially you can't run the 140ps map on a 100/115ps engine.
You can re-map them via the normal way as Martyn (Vantuner) would do to get the best out of them though.
Re: IDS remapping
Postby gregd72002 » Tue Sep 04, 2018 10:47 am
Yes, it is Euro 5 2.2 (125ps)
As of yesterday evening I managed to flash different PCM calibration file (one from 155ps version). The van started and drover but had way less power than the original 125ps.
I am back to stock calibration file now.
Different turbo/injectors would explain this behaviour for sure. Interesting though! Might dig through ECAT to check the part numbers.
gregd72002
Re: IDS remapping
Postby gregd72002 » Tue Sep 04, 2018 12:36 pm
The injectors and pump are the same between the versions I've used but turbo had a different model. Maybe this was the problem.
I'm gonna give it another go with a model that is closer to mine: WF0YXXTTGYFC75793 (same injectors, pump & turbo just different power). Could someone extract the calibration file name for this vin please?
gregd72002
Re: IDS remapping
Postby knobby1 » Tue Sep 04, 2018 11:15 pm
gregd72002 wrote:The injectors and pump are the same between the versions I've used but turbo had a different model. Maybe this was the problem.
Can't help with the Euro-5's I'm afraid.... :oops:
Re: IDS remapping
Postby gregd72002 » Wed Sep 05, 2018 9:31 am
I found all the information on Ford ETIS Online. Programmed it with the new calibration file and all works fine :)
Now the question is - has the new calibration actually increased the output of the engine :?:
gregd72002
Re: IDS remapping
Postby Oliver01495 » Wed Jan 26, 2022 9:55 pm
Hi gregd72002
I have tried mapping my custom 125ps with a calibration number from a 155ps but ids keeps saying invalid calibration number or not recognised. Do you know why? Is it because I’m using the the lasted vcmm?
Oliver01495
Return to Transit Custom
