Rear twin wheel bearing kit's for transit MK3
Postby vana mana » Tue Sep 04, 2018 1:54 pm
Ok
Can anyone that really knows there stuff about twin rear wheel transits especially MK3 - can you tell me if the bit where the bearings and seals sit are all the same on twin rear wheelers
I've just found a kit on e bay and they advertise it for Mk2 through to MK6 and now I've gave them my vehicle Reg they say they can't help. . But in there picture there is a lock tag washer which I believe is only used on twin rear wheelers
I'm wondering that they just don't want to commit in case it's wrong ?
Are those middle chunks of metal that the bearings and seals sit in all the same for mk3
Any help appreciated as always
Hank you
vana mana
Re: Rear twin wheel bearing kit's for transit MK3
Postby wojciech » Tue Sep 04, 2018 7:20 pm
vana mana wrote: can you tell me if the bit where the bearings and seals sit are all the same on twin rear wheelers
Ok, maybe my English is too poor and maybe I didn't rightly understand you.
Are you talking about HUB, where inside are two bearings and two seals?
If the bearings and seals are the same in Mk2/3/4/5 and Mk6, hubs must be the same inside.
Outside:
- hub in Mk1/2 and Mk3 has six threaded wholes for screw mounting halfshaft mushroom.
- hub in M4 and Mk5 has screwed studs in this six holes - so for halfshaft mounting are using nuts (not screws).
- hub in Mk6 has the same bearings and seals, but outside looks a little different (red arrow). And again for halfshaft mounting are using screws.
So: hubs, bearings and seals between models Mk3,4 and Mk5 are fully replacement. It can be a little problem with nuts/studs for halfshaft mushroom.
About models Mk2 and Mk6 - maybe, but only... maybe.
For Mk1 - bearings are the same, seal is only one and different.
wojciech
Postby vana mana » Wed Sep 05, 2018 10:48 am
Thank you again , I really appreciate your bout and pictures
Yes this is the part I'm n about n the twin rear wheel hub / bearing bit
I will it the e bay numbers up for the advert
Please if you have time let me know your thoughts ?
Personally. I think it's because my registration number comes up as an S V O and automatically sellers just say no it won't fit
Thank you
vana mana
Postby vana mana » Wed Sep 05, 2018 10:52 am
E bay item number is
https://www.ebay.co.uk/itm/152561675620&seller=&toolid=10018&52578719" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/152561675620
I have just purchased 2 new twin rear wheel drums with same numbers / cross over numbers
I gave them those numbers too they then said it won't fit or something along those lines ?
vana mana
Postby wojciech » Wed Sep 05, 2018 1:39 pm
vana mana wrote:Please if you have time let me know your thoughts ?
Thank you
I am very happy to help you, but first you must help me to understand your problem. I consulted your posts with very good Anglicist - and still I don't really understand any of that. Image
What you need to buy, what you bought, what went wrong???
wojciech
Postby vana mana » Wed Sep 05, 2018 6:27 pm
Hi again
I want to buy the bearing kit in the above picture I posted from e bay but the seller sais it's not he correct ones for m f Reg mk3 twin rear wheeler
vana mana
Postby wojciech » Wed Sep 05, 2018 8:49 pm
vana mana wrote:Hi again
Ok, now I understand.
So I checked bearings dimensions (in many sellers and in SKF catalog), and :
- bigger bearing has outer diameter 97 mm (sometimes is written 96,8 mm with bigger precision), inner diameter is 57 mm (56,8 mm, 57,1 mm)
- smaller bearing has outer diameter 85 mm, inner diameter 51 mm (sometimes is written 59,8 mm).
In net in ads is plenty of mistakes. :evil: In ads https://www.ebay.co.uk/itm/152561675620&seller=&toolid=10018&52578719" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/152561675620">https://www.ebay.com/itm/https://www.ebay.co.uk/itm/152561675620&seller=&toolid=10018&52578719" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/152561675620 outer diameters looks ok (96,8 and 85 mm), but inner diameters are 52,2 and 50,1 mm - I think it is error, and should be 57,2 and 51,0 mm. But we cannot be sure about it. So you can look somewhere else.
https://www.autodoc.co.uk/car-parts/whe ... ab-fac-fad
wojciech
Postby wojciech » Wed Sep 05, 2018 8:54 pm
https://www.ebay.co.uk/itm/REAR-WHEEL-B ... SwpDdVbuYe
They are from Poland and they look as conscious. No errors... :lol: Reference OE/OEM Number: 0634048, 0634049, 5015650
wojciech
Postby vana mana » Thu Sep 06, 2018 11:32 am
Wow
Thank you
I'm astonished at the effort you have made to help me out
So you think this last set should fit the rear hub bearing part
vana mana
Postby wojciech » Thu Sep 06, 2018 2:30 pm
I think not only this last one link is ok - in net is plenty correct ads.
I suppose bering kit from your link (E bay item number https://www.ebay.co.uk/itm/152561675620&seller=&toolid=10018&52578719" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/152561675620) is also ok. But in ads are errors in dimensions - because of sellers sloppiness.
But this last is given without any errors and with correct Ford Finis nr 5015650.
wojciech
Postby vana mana » Sat Sep 08, 2018 8:37 am
Thank you again
I have ordered a set for both sides and git a bit of discount
vana mana
