Electrical problem
Electrical problem
Postby Markburb31 » Thu Sep 06, 2018 1:08 pm
Hi just got a no 7 08 plate transit and now the end light is on the Speedo doesn't work properly and back lights one side has light but no brake and other side has brake and no light.
Can anyone shed some light on this.
Thanks in advance
Markburb31
Re: Electrical problem
Postby loot » Thu Sep 06, 2018 8:55 pm
In not sure what the question is :oops:
Ids map here
loot
Postby knobby1 » Fri Sep 07, 2018 12:00 am
Markburb31 wrote:Hi just got a no 7 08 plate transit and now the end light is on the Speedo doesn't work properly and back lights one side has light but no brake and other side has brake and no light.
Thanks in advance
What Loot said..??
Have you had the codes read..??
Postby Kenton » Fri Sep 07, 2018 10:22 am
Thanks in advance
Indeed from what i can make out, have the codes checked. With the rear lights, take the bulbs out and check them. If they are ok you may also want to check to see if there is an earthing problem?... Please also confirm you questions more clearly.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby loot » Fri Sep 07, 2018 11:38 am
Have you recently fitted light bulbs? Check that there hasn't been a twin filament bulb put in wrong or back to front (don't recall them on the transit but check that) also if there is a tow bar socket check it hasn't got water in and corroded. Also the light connectors go rusty and crap out, also on my mk6 right side loom I have to twist the whole lot around 180 degrees for them to work, probably a broken wire.
Ids map here
loot
