Central locking
Central locking
Postby johnarundel23 » Thu Sep 06, 2018 5:55 pm
Hi my 57 plate transit , long wheel base with 2 side doors , when I press fob it beeps , won’t lock , checked all doors to see any obstruction none , changed fuse , wiring in back doors seems in good order , still won’t lock . Tried to use key in drivers side door nothing not locking , sat inside can’t push lock button in on drivers or passengers door any ideas or where can I take it as locking it is urgent , thanks John
johnarundel23
Re: Central locking
Postby knobby1 » Thu Sep 06, 2018 11:52 pm
It will probably be one of the side loading doors not making good contact withe the three little spring pins, low down on the rear of each door....check and clean them, then check the contacts are actually working and touching the pads.
