Replacing Side Door Handle Transit Van
Postby isladeiona » Thu Sep 20, 2018 6:06 pm
Hi, Ive looked the threads but cant see the info. Please can someone guide me how to change the sliding side door ..handle. I am guessing a woman can do this too? I just need guidance thanks.
isladeiona
Re: Replacing Side Door Handle Transit Van
Postby Airthies » Thu Sep 20, 2018 11:21 pm
Need to do mine will get some pics if you need them.
But basicaly it's got a 10mm nut on the back of it holding it on.
You need to take the door card off while the doors shut first though. Just get a wide flat screwdriver behind the card where the plastic plugs are and they'll pop out, to protect the paintwork a bit of cardboard between the door and the screwdriver will be fine.
The cables are hooked into the handle and the outers are just clipped into the backplate.
If your new handle comes without a return spring the TORXS SCREW is LEFT HANDED!!!!!!!
(Eighty tighty - lefty loosey does not work with the torx screw!)
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby isladeiona » Sat Sep 22, 2018 10:23 am
THANKYOU, @Airthies. Your reply has been very helpful and much appreciated. I will give it a go.
isladeiona
