Hi, Yesterday i had a new problem with the van. During a climb the van started losing power. You could hear the turbo blowing, but with full throttle nothing changed. Shutdown and restarted all ok. No errors on the Ecu and no Engine light.
Can be the Egr? I changed it 3 month ago. Now I've removed it with a steel plate. I will see if something change but i'm not sure only the egr can cause a loss of power. Maybe some stupid sensors?
Thank you,
Regards,
Marco
