Mk3 TD 100 Starter Connection
Postby Saukstas » Mon Sep 24, 2018 1:44 pm
Hi,
maybe someone has photo/schema, how to connect starter?
I have taken it out & forgot where the small wire should go?..
On this bolt (attached), as i remember...
Thanks!!!
Saukstas
Re: Mk3 TD 100 Starter Connection
Postby knighty1981 » Tue Sep 25, 2018 1:46 am
two wires, big wire to the big bolt
little wire will either go to a small screw terminal or small spade connection
knighty1981
Postby Saukstas » Tue Sep 25, 2018 5:57 am
so, little wire will go the bolt, where i painted (not very professionally...) red?
Saukstas
Postby knighty1981 » Tue Sep 25, 2018 9:43 am
no... that's the big bolt.. for the big wire from the battery
there's 2 big bolts, one goes to the battery, the other to the motor body
there's a small connection there for the small wire
knighty1981
Postby Saukstas » Tue Sep 25, 2018 1:56 pm
Oh, yeah, that small one is little underneath big ones, wright?
Thanks a lot!
Saukstas
Postby Saukstas » Fri Sep 28, 2018 12:15 pm
maybe someone has some schema, picture?
Appreciated
Saukstas
